Question about General Electric GE Industrial Dept. TM2020CCU Main Breaker Load Center
I have an older GE TM2020 box that I want to upgrade to a TM3220 or TM4020. Will I have to buy a new breaker module, etc.? Can I throw in a larger GE panel in the existing box? Thanks
I need an interior panel and door for a GE tm 2020 k342 mk1. If you do the swap can I buy your old interior panel?
Thanks-rub2raceatyahoo.com
Posted on Mar 15, 2011
GE Sensor Microwave Oven made in 2008 doesn't heat up food
If you do not have any electrical / electronic repair experience I suggest replacing your microwave oven. The cost for repair might be excessive depending upon where you live and you might find a newer microwave oven with features that you like which were not on your older model. The prices of microwave ovens have become lower in recent years and that almost makes microwave ovens "throw away" devices. It has happened to radios, televisions, etc. I used to be in the repair business and the throw away stuff pretty much ended my business.
Feb 10, 2015 | GE Microwave Ovens
Slow computer
Not usually, unless you are replacing the primary drive with a SSD perhaps, but the speed improvement will be minimal. You're just running an older mainboard/processor and the newer games and apps are leaving you in their dust.
Dec 11, 2013 | ASUS P5PE-VM Motherboard
How do i install a 14-3 wire with ground to the breaker
Following wiring diagram is for general purpose household 120V-240Volt service.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-10-1000.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/Color-codewire.html
Why are you asking that question without saying what you are wiring? 120Volt, 277V, 480V etc?
What does rating plate say on device you are connected to 14-3 wire?
And what amp/volt/watt rating are you connecting to 14 gauge wire?
No electrician would omit that information.
14-3 wire is usually only for 3-way switches and other light duty applications.
Must be connected to 15 amp breaker and no larger.
Apr 08, 2013 | GE 15 Amp 1 inch Single Pole Circuit...
Can a 100AMP Culter Hammer Main Breaker Be Upgraded to 150AMP Without Changing the box or wiring?
only if your main wires (ie. line/feeder wires) are larger than a #2 awg wire size. #2 awg size wire is code and the right size wire for 100 amps. So, if you have larger wire coming into your service (eg. #1 THHN or larger) - then you can. Otherwise, you'll have to UP the wire size for the appropriate amperage. I hope this gives you some idea! Good Luck!
Sep 07, 2011 | Cutler Hammer 100 Amp Main Breaker...
I have a GE Profile JT952series Electric Double Oven and the keypad is not turning on the bottom oven
Check your breaker box to make sure the breakers are ON.. these typically are double throw breakers.. it is possible one of them has been thrown open.. so flip that double throw off and back on.. then check..I have seen one side of these breakers fail.. unusual.. but it happens.. then a replacement is in order.. regardless. visually it may appear the breaker is closed..but upon closer inspection.. one side may be "spongy/open". There are always exceptions..so examine the breaker box carefully.
If one breaker is open..it would be wise to keep an eye on things to determine how it got that way in the first place. If the breaker will not close or throws/pops again..you either have a bad breaker or a wiring problem..in some cases the element may have grounded out..or burned a wire.. etc.
Next thing to check for is a bad element.. Remember..this is a 220volt hot circuit with a high amperage breaker.. BE CAREFUL.. USE CAUTION.. Failure to do so could result in serious injure or DEATH.
Turn off power at the breaker box to the oven.. test the working over to make sure the power is OFF.
Remove the oven racks
Remove the screws at the base of the element
Pull the element toward you
Note how the wire(s) are connected
Disconnect the wires.. checking for broken or lose terminals..if lose or broken..repair.
You will need a volt ohm meter for the following..
Test the Element for continuity. Place each probe on the terminal ends (manual will have ratings) generally if you have continuity it probably works..
Test for a grounded/short.. one probe to element the other to terminal end..if you have continuity.. it's shorted out. Test both terminals
Replace with a new one if needed.. reverse procedure. Turn on the power .. and test for proper operation.
Again.. 220 VOLTS..HIGH AMPERAGE.. USE CAUTION..not doing so could result in injury or DEATH
After you have done the above..and get an all pass..then it's on to controllers and temp sensors.
Best of luck
Apr 19, 2011 | GE Profile JT952 Electric Double Oven
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
Throwing breaker
Throwing the MAIN BREAKER should not happen. Calculate the distance to your main box. Tell me the wire gauge or breaker amperage. Whatever you do, do not get a larger breaker! If its a breaker on this unit Its probably doa with current leak possibly. DO NOT USE fire hazzard IF SHE TRIPS!!! let me know if its your main breaker inthe house. Hopefully you dont have crappy cloth wiring.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Broken coffee carafe
Was expressing my opinion. I will buy a different model when I find one Thanks
Jul 31, 2009 | GE 106591 Coffee Maker
Want to replace the "guts" of a G.E. load center in small box
You won't find any "guts", like longer busbars, to upgrade. The panels pre-date most of the codes and you will not find replacement parts, except maybe a breaker or two. For panels that old you are looking at the possibility of having aluminum wiring and/or two conductor wiring (hot and neutral). In either case, your local code office or utility company will probably require you to update to current requirements. You cannot connect aluminum to copper without nickel connectors because of galvanic corrosion, and if you are disturbing any of the wiring you will probably need to upgrade to three conductor (hot, neutral, and ground). You should be able to buy "Square D" HOM series replacement panels with breakers for about $120 or less.
--Peter Nomikos, ICC Master Code Professional
Building and Zoning Director, City of Mauldin, SC
Feb 24, 2009 | Gb Electrical 100 Amp GE Load Center
Thomson DTI550 set top box problem
Hopefully those of you who still own their DTI550 had it operational this last weekend and picked up the download that fixed this? If not, it should be repeated some time soon. So don't throw your 550 away yet!
Oct 02, 2008 | Televison & Video
General Electric GE Industrial Dept. TM2020CCU Main Breaker Load Center Logo
697 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
