Question about Delta Rockwelldelta 14" Hinged Wood Band Saw Part Manual
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the blade slips off. s
  • 32 Answers
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Posted on Nov 15, 2010
Need to know how to change blade on rockwell motorized miter saw model 34-010 8' blade
Some blades have a little hole; in them to put a small screwdriver or even a nail in to hold the blade when you put a wrench on it to loosen the nut. If there is no hole I use a small screwdriver and put it in the teeth to hold as I turn the nut out Mine has a cover you have to undo before taking the blade off.
Sep 29, 2017 | Blade Saws
I am looking for a manual for a Rockwell Sports Model RK7453 band saw?
Home Depot has the Use and Care Manual for the Rockwell RK7453 on the product page: http://www.homedepot.com/p/Rockwell-2-5-Amp-9-in-Band-Saw-with-59-1-2-in-Blade-and-Work-Light-RK7453/202791039 . Look on the right side of the page as you scroll down. The direct link to the manual is currently: http://www.homedepot.com/catalog/pdfimages/45/459477a0-deee-4b28-aff3-713b3db859fd.pdf .
I hope this helps.
Jun 08, 2017 | Saws
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
I have an old rockwell 14" bandsaw and am having
Follow these instructions, but before adjusting the guides see the link below.
It sounds like you have not correctly adjusted the guide blocks that ride on either side of the blade, both above and below the table. These small rectangular blocks can be adjusted by loosening the allen set screw in the guide that holds them in place. They should be pressed in against the blade lightly, without deflecting the path of the blade out of square to the table. (You may first have to sand the ends of the guide blocks square if they are grooved from use. Use a belt sander and a pair of vise grips to hold the blocks while you square them off.) Anyway, the guide blocks should allow the blade to run smoothly, (you might hear a tick tick of the weld passing through the blocks), but will not allow the blade to deflect from side to side. Correctly adjusted, they keep the blade aligned with the bearing behind it, and prevent the problem you describe.
Only after you have correctly adjusted these guides just behind the set of the teeth, and the blade is turning freely by hand when you spin the upper wheel, do you bring the bearings in to kiss the back edge of the blade. Make sure the bearings are lubed to spin freely with a little bearing lube or wd40, then bring both the uppper and lower bearings in until they almost spin or just barely spin when the blade is turned by hand. When you exert a little pressure during cutting they will then hold the blade in place between the guide blocks, so the blocks don't wear the teeth away. Please see this link for detailed instructions I gave another user. (possibly also here) They will apply to your saw as well. If you have any questions or further probelms, write back. You may also wish to check here for a pdf manual for your saw.(check both rockwell and delta).
If you take some care to properly tune the saw, you will get much beter cuts and the saw will be a joy to use.
Nov 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
I have a 12" Craftsman Band saw and the blade keeps coming off. What adjustments do i have to make to put on a new blade and keep it on?
The wheels have to be true at 180 degrees facing each other. Use a metal rafter square if needed to align the trueness of these wheels. If one is angled out ward the blade does come off the wheel
Jul 06, 2010 | Saws
Bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Aug 22, 2009 | Craftsman Saws
1/8" metal blade keeps coming off
Yes there is a tilt adjustment on the top wheel used to set the tracking of the blade, a small amount of adjustment will change tracking dramatically
Mar 23, 2009 | Saws
Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Nov 17, 2008 | Saws
Delta Rockwelldelta 14" Hinged Wood Band Saw Part Manual Logo
257 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
