Question about HP Compaq Computer Speakers
Sound is perfect with headphones plugged in but no sound from internal speakers, On checking Control Panel/Sound it states that no audio devices are installed. The internal speakers worked perfectly until about a week ago.
  • tkierans Nov 14, 2010
    Thank you for pointing me toward the bleeding obvious. Worked like a charm - my thanks again for restoring sanity.
  • HP Master
  • 629 Answers
What you can do is check if the default audio device for your sound card/audio controller is available and try to set your speaker settings to the laptop speakers. Another thing you can do is to disconnect the headphones and then reinstall the audio driver.
Posted on Nov 14, 2010
  • Rodie Nov 14, 2010
    you're welcome. glad it worked and helped!
Toshiba laptop Internal speakers loss of sound while playing games and watching videos .Sound first 10-15min then no sound.only way to get sound back by going into sound settings and disable speake
Could be an audio driver issue. Does the sound work okay if you plug in external speakers or headphones? If problem persists with headphones/external speaker
Boot into safe mode (F8 on windows restart)
Select Safe Mode
When windows loads (it will take longer than usual).
Control Panel > System Properties> Device Manager > Delete/ Uninstall your audio drivers, reboot your machine - audio should work now.
Apr 17, 2014 | Toshiba Computers & Internet
No sound on asus k52f
You may call on 1-800-585-2494 for support on Asus.
Nov 11, 2011 | ASUS K52F-BBR9 Notebook
I have laptop Compaq nx 8220 , the internal speaker of my system is not working however the sound through headphone is perfect !
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | HP Compaq Computer Speakers
There is no sound in my laptop
1. Check the volume settings of the computer.
2. Try connecting external headphones to check if there is any error with internal speakers.
3. Reinstall Audio drivers and its updates.
4. Click on Start, Control Panel >Hardware and sound.
5. Open sound properties windows and in the playback devices tab, check if the internal speakers/HP option is selected as the default audio device.
Note: VPCEB series computers have a known issues with the internal speakers. The best option is get the internal speakers replaced for EB series.
Prove exact model of your Sony VAIO notebook for a more precise reply.
Jun 03, 2011 | Sony VAIO Notebook
Suddenly, my speakers won't make any sound. this morning they worked perfectly, and i've checked the input is fine (it works well when i plug headphones in the volume control) and if i plug my ipod, still...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 01, 2011 | Creative Labs I-Trigue 3220 Computer...
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
No sound through speaker or headphone
double check the speakers connection. Make sure you plug it in the right hole.
May 06, 2008 | Fujitsu LIFEBOOK S6010 Notebook
HP Compaq Computer Speakers Logo
460 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
