Question about HP Pavilion DV5234US Notebook Laptop
Image displacement the image of my laptop the individual lines keep moving about the screen causeing the image to compress and repeat the top part of the screen down at the bottom. so far i have determined that it is not a software problem but something with the screen its self or some of the connecters i dont know. is there anything i can do or should i take it to a repair shop. you have no idea how hard it is typing this on my laptop. please help
    Genius:
  • 2,028 Answers
First try checking the connectors on the screen, screen to inverter, and screen to board. If these are seated well, then it's either the inverter or the screen itself.
Posted on Jun 18, 2008
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
Aug 01, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
I just changed the hydraulic master cyl and bleed the clutch over a few days with 1/2 bottle of DOT-4. The bike starts fine in neutral but locks up when put into gear. How do I get the clutch plates un...
It sounds very much like you have still got air in the system, have you tried bleeding the system with individual strokes Eg: bleed tube on nipple going into a glass jar with some fluid in the bottom of it. Release the bleed nipple operate the clutch, keeping the clutch gripped tighten the bleed nipple. release the clutch then open the nipple and grip the clutch again then close the nipple release the clutch etc etc until there is no bubbles appearing in the fluid in the jar. Remember you can compress air and so any air that is in the system will compress instead of displacing the fluid. Fluid cannot be compressed therefore it must be displaced, so no air in the system then displacement occurs. Failing that release the outflow from the MC just enough for fluid to escape then wrapping a cloth around the outflow pipe to avoid fluid dripping on paintwork, pull the clutch then tighten the outflow pipe, release it once again and pull the clutch then tighten the pipe again when you feel sure there is no air in the MC making sure the outflow pipe is tightened then move down to the slave cyl and bleed as describediously prev
Sep 23, 2011 | 1998 Yamaha Royal Star XVZ 1300 A
I have a Toshiba laptop.. completely new, and it was 700 dollars. When I go onto facebook, or clothes shopping, all of the pictures are blurry... but text is fine.
I understand that you are having the issue that you are getting Blurred Pictures while accessing the sites. To answer your query with the proper steps the information about the Browser you are using is required. If you are using the Internet Explorer you may follow the steps: Launch the Internet Explorer browser by double-clicking its Desktop icon or selecting it from the Start menu. Click "Tools" in the top menu bar of Internet Explorer. Select "Internet Options" from the drop-down menu. Click the "Advanced" tab and scroll down to Multimedia. Check the box next to "Smart Image Dithering." This will help to ensure that images are loaded properly. Right-click on the image in Internet Explorer and select "View Original Image" from the pop-up menu. This will force the browser to display the original image. Check to see if any installed Internet browsing accelerators are compressing your browsing too much and causing the blurred pictures. For example, the MSN Accelerator (used to enhance the speed of an individual's Internet connection) can sometimes cause blurry images due to high levels of compression. Right-click the "MSN Accelerator" in your Windows task bar (bottom right-hand corner of your PC's screen) and set the level of compression to "None." If you are using the other browser you may try resetting the settings. Even in Internet explorer you may reset. But note that resetting the Brower may deleted the saved information like password and auto fill.
For additional help if you need please revert back with the exact details like the browesr you are using.
You may also try updating the flash player and check the operations
Sep 03, 2011 | Toshiba Satellite P100 Notebook
My TI-84 Plus graphing feature is connecting my trig functions across the asymptote. How do I make it stop doing this?
Press MODE and change "Connected" to "Dot".
Alternatively, you can change the style for individual graphs. In the Y= screen, move to the line then press left-arrow to move past the = sign, then press ENTER repeatedly to cycle through the different graph styles.
Nov 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do i get rid of a dark thin line going across my lap top ???
That cannot be repaired as the screen on your notebook has layers and between those layers gas is compressed within thin columns. In your case your screen got a minute leak in one of the columns and now that column is unable to produce image. Hence, It can't be repaired. You have to change the entire screen.
May 20, 2010 | Compaq Presario M2000 Notebook
Unstable image on television screen: Hitachi Model # 27CX3B
Check for poor soldering around Vertical Driver Ic.
Nov 11, 2008 | Televison & Video
My tv has this lines that bend over the front top of the screen and when an object moves through the lines the image appers from the the top of where the line begins...and the tv goes black every once and...
This sounds like a vertical deflection fault. There are some components that are failing in the vertical deflection area that are starting to fail. It is very common in many of the sets that there are electrolytic capacitors in the vertical amp section that are gong out of specifications.
When you have at the top or the bottom of the screen where the vertical axis is compressed, and the picture in the compressed area looks like it is inverted and going over on itself, this is called "vertical fold-over".
An experienced TV service technician should be able to service this for you.
Jerry G.
Apr 18, 2008 | Televison & Video
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
HP Pavilion DV5234US Notebook Laptop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
