Question about Roper Washing Machines
Model: Roper RAL4132VW I read this answer http://www.fixya.com/support/t5201733-wasaher_not_spin_or_drain and have the same issue. However it's inconsistent so I can't pin down if it's the lead switch or motor. Here's what I know: 1. Right now I can run a full wash cycle 1 of 5 attempts. The others stop and leave me with a full tub. Failed cycle can happen after initial water is run or prior to spin. 2. Lid Strike is secure 3. Lid switch - not sure. I removed it and cleaned the soap crud, checked connections, and screwed it in tight. The first run went 100% perfect. But none have worked since. 4. I hear it click each time Question -- Can it click, but not work? Where the switch has an internal problem that just causes it to fail. About the motor: 1. Hard to tell if it is the problem, or if it's just not being triggered to run. ALSO: There is an odd smell emitted around the attempts where the cycles fail to run. Kind of a slight burn smell.
  • Roper Master
  • 43,501 Answers
A couple of thinds...
The lids switch can go bad and still click... but I don't think that your problem is the switch...
I think that your problem is the motor... it can start to go bad...work sometimes and not other times...
The fact that you have a hot smell when it does not run leads me to the motor conclusion....
I would get an electric meter or have some one with an electric meter check to see if you are getting power to the motor when it should be running...this will confirm my theory...
heatman191
Posted on Nov 14, 2010
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
RAX7244JQ0 Roper washer fills, starts to agitate but then it stops on the spin cycle and will not drain. not sure which part to replace--timer?
Hello, Thank You for using FixYa. I will be helping you today. The lid switch failed you need a new lid switch part number 3949247 this link has the part and a video how to change it http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Roper Washing Machines
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | KitchenAid KHWS02R Front Load Washer
Spin cycle of Roper wash machine-Whirlpool won't work.
heatman101
Jun 18, 2010 | Washing Machines
Not spinning
heatman101
Jun 17, 2010 | Roper RAB2121KW Top Load Washer
Won't spin out
heatman101
Jun 03, 2010 | Roper RAS8244KQ Top Load Washer
Washing machine stops before rinsing
heatman101
May 31, 2010 | Roper RAS8445KQ Top Load Washer
Washer does not drain and spin
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
The spinner is not rotating and is making weird noise.
heatman101
May 14, 2010 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
