Question about Husqvarna 20" 60cc Rancher Chain Saw 460
Husqvarna 460 rancher saw- chain brake is tripped and locked; cannot replace cover How do I reset the chain brake?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
Pull back on the chain brake, this will release it.
Posted on Nov 15, 2010
High and low setting for hasqvanna 460
Husqvarna 460 Rancher Manuals
www.manualslib.com > Brands > Husqvarna Manuals > Chainsaw
Manuals and User Guides for Husqvarna 460 Rancher. We have 3 Husqvarna 460 Rancher manuals available for free PDF download: Operator's Manual ...
Jul 23, 2015 | Husqvarna 20" 60cc Rancher Chain Saw 460
Replace sprocket on rancher 460
The factory do not offer a rim sprocket for the 455/460, they are classed as semi pro saws and as such get a spur sprocket, there may be an Oregon after market one available.
Dec 29, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
Chain brake locked
Take off the clutch cover and make sure the area isn't gummed up preventing the brake from disengaging. Generally the brake consists of metal strap that goes around the clutch and is tightened when the brake bar is pushed forward. The tensioning is adjusted through a spring mechanism and it may need to be loosened as well. Hope this helps!
Jul 04, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husqvarna Chain saw 460 rancher chain brake problems
THERE LINKED TOGETHER SOUNDS LIKE, TAKE THE SIDE PLATE OFF THE SAW AND BLOW IT OUT WITH COMPRESSED AIR, THIS I THINK WILL SOLVE THE PROBLEM . IT'S JUST A GOOD IDEA TO BLOW OUT THE SAW AFTER EVERY USE .THINK SAFETY !1. JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Husqvarna Garden
On the 460 rancher does the chain oil tank have a breather pipie? and how easy is it to replace all the pipes. as it seems to block up untill i open the tank and air gets in
The breather sits in the bar pad, it is a sintered plug that covers a duck bill valle, you would need to screw a self tapper into the plug so as to pull it out, this will of course desroy the breather and would need replacing
Jul 07, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husq 455 rancher chain saw. the chain locking spring in the cover is in the lock position and will not mount on the saw. how do i release the spring tension?
you should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting a log with 455 rancher chain locked up took cover off replaced chain ,chain spins with cover off put cover on chain is locked up again husqvarna
It sounds like the chain is too tight. Loosen up the tension on the chain by turning the tensioning screw located on the end of the saw where the bar goes out.
Feb 26, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting with 455 rancher chain locked up took cover off ,replaced chain and put cover on still locked up
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 20" 60cc Rancher Chain Saw  460 Logo
1,043 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
