Question about Aprilaire 700 Humidifier
Water leaking - Aprilaire 700 Humidifier
  • 425 Answers
Hi, you can use this as a guide...
aprilairehumidifierparts.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Hope it helps.
Thanks for using fixya...
Posted on Nov 17, 2010
After 7 to 10 days, all water leaks on floor.
Does it get heated? If so, Heat makes filter dry and it starts to leak.
Mar 24, 2016 | Humidifiers
Water coming into humidifier has recently begun to leak out from connection to the discharge tube.
THE WATER CONNECTION TO THE INPUT OF THE HUMIDIFIER IS LEAKING? - -IF THIS IS THE CASE, SHUT OF THE WATER SUPPLY TO THE HUMIDFIER, UN-SCREW THE INPUT CONNECTION, USING SOME PLUMBING WHITE CONNECTION TAPE, WRAP A COUPLE OF TURNS UNTO THE THREADS, RE-CONNECT AND TURN ON THE WATER SUPPLY. IT SHOULD STOP LEAKING.
IF ITS THE OUTPUT OF THE HUMIDIFIER OR DISCHARGE TUBE, THIS IS NOT UNDER ANY WATER PRESSURE LIKE THE INPUT IS, AND IT IS POSSIBLE THAT THE HOSE MAY BEJUST LOOSE OR CRACKED AT THE HUMIDIFIER. CUT OFF THE HOSE AND RE-ATTACHING WILL WORK OR MAY EVEN NEED A NEW HOSE.
Feb 20, 2011 | Aprilaire 700 Humidifier
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Aprilaire 700 Humidifier Logo
96 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
