Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I have a tear in the top of my hose. Right by the handle is there a way to shorten the hose a few inches at the top to repair the hole?
  • 694 Answers
You'd be better off using duct tape on it. Ensure the wiring is intact first, then wrap a couple wraps of electrical tape around the hose, then 2-3 of duct tape. May not be pretty, but safer than cutting the hose and wiring just right to get everything safely connected.
Posted on Nov 14, 2010
My mother's Bissell 66t6 has a tear in the hose very near the handle. I'd like to remove all of the duct tape she put there and disassemble the handle so that I could shorten the hose by a few inches at...
I can't say for sure without seeing your model but this can. E done on most vacuums as long as it doesn't have electric wires to run a power nozzle. Some hoses simply unscrew from the fitting and some have an extra connector. The easiest way if it won't easily come out by twisting the hose counter-clockwise is to cut the hose at the bad spot and pull on the hose and it will come apart so you can remove it. Sometimes they have glue or silicone holding them in but if you pull you should be able to remove the old hose and screw the good part back in.
Nov 03, 2013 | Bissell 66T6 Bagless Canister Cyclonic...
Repair wertheim 3180
The hose probably is old enough that it will split repeatedly until you give up and replace it.
Jan 10, 2018 | Vacuums
Should I replace the vacuum hose or simply shorten it if a hole developed near the vacuum canister base? What are the disadvantages of this? For now I am doing duct tape, which is not so elegant as dust...
You can just shorten it as long as there is not a underlying power supply in the hose itself. after you shorten it use a "hose clamp" to hold the shorten hose in place. :)
Sep 21, 2010 | Kenmore 22822 Canister Vacuum
My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Mar 21, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a torn hose on my Samsung Quiet Storm should I try to repair or toss it. Mfg no longer makes replacement hose
The early hose on these was prone to tearing. If you are careful you can shorten it once. Beyond that it will become too short to use on the vac properly. This hose was copied from the original Black and Decker hose and power head kit and was likely upgraded by a flex vinyl molded hose which should be more resistant to tearing.
Some vac shops carry hose "refills" and a Samsung dealer may have one in stock even if the hose was discontinued. The vac is good quality in its general design and worth fixing although the original diameter of this hose may be tough to match
Oct 30, 2009 | Samsung Quiet Storm 9069 Vacuum
Shorten hose, Beam
If your Beam has a fixed handle RUBBER hose with switches and is deteriorating between coils, you can dismantle the handle (or wall end) with about 6 screws. If it has a swivel handle with switch it can not be shortened. If it is not switched and non electric, the cuffs simply unscrew and the vinyl can be cut and reglued with vinyl adhesive.
You will see once open the handle that the hose has fine wiring wound through its shell and this wiring controls the switching between the handle and the vac. You must unwind the hose from the inside handle stem, cut short with a utility knife and wire cutters and then screw the fresh hose end back onto the handle stem.
The hose should also be glued from the inside (after cleaning with a dry cloth) with a contact type cement suitable for rubber and plastic. Generally PLIOBOND is used.
Then splice your wiring and reassemble the handle.
Oct 24, 2009 | Vacuums
I have a large lego stuck in the middle of the hose on my hoover
Ok This same thing happend to my wifes vacuum. If its on the straight part use a small broom handle. If its down deeper you can cut the handle in short pieces as if to make a small train. Drill a small hole in the center of the blocks or broom handle pieces. I cut mine 1 1/2 inches long so they can make the turn. Next take a stick and force the clog back words.keep tapping and shacking the hose and stick till it drives the clog back. Keep your tool hanging In a good place till you or someone else needs it. I had to make 2 of them, Because she has a small light weight vacuum with a smaller hose on it. i got a dial rod that fit just right in the hose, And made a uncloger for the small vacuum also.
hope this was helpfull
Sawdust
Aug 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Torn Hose
HI.
You can use evo stick glue.
But normally once it has ripped open it will do it again so probably best option fit new hose.
http://dysonmanuals.inc.io/
Chris..
Nov 03, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
102 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
