Question about Whirlpool 33 in. ADP6830 Free-Standing Dishwasher
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
  • 27 Answers
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Posted on Feb 21, 2011
What is error code F6 E5 in Whirlpool Dishwasher ADP 5510 IX ??? The dishwasher keeps stopping after 2-3 min of working.I haven't touched anything since the day I bought it (2 months ago)
Fault Code F5
Dishwasher Spray arms are clogged or otherwise malfunctioning
F6 Fault code
Dishwasher doesn't detect any incoming water despite the water inlet valve being open.
Nov 10, 2016 | Whirlpool Dishwashers
Start light flash 2 times on a Whirlpool ADP 6940.
Whirlpool dishwasher start light flashes 7 times repeatedly and wont start
May 24, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
I have a whirlpool sixth sense dishwasher and
F3 error fault code
Aug 25, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 33 in. ADP6830 Free-Standing Dishwasher Logo
1,387 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
