Question about Whirlpool RBS275PD Electric Single Oven
What does F5E2 mean..... it is stopping me from cleaning the oven.
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
When I turn on the oven there is a clicking sound coming from the control unit. Stopped when the oven heated up. Do I need to be concerned? Does this mean something is going wrong? I have the Kenmore...
If everything is working ok don't worry .
It is probably just the thermostat 'cycling' in and out then stopping when it is up to temperature.
Dec 19, 2010 | Ovens
I'm trying to use the self clean feature on the oven., After a short cycle- I get a F9 on the temperature control and the oven stops cleaning. What is wrong?
The F9 means Lock switch. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. You can check for loose or overheated wire connection.
Nov 26, 2010 | GE JTP15 Electric Single Oven
Everything works but oven will not heat. It stop right after a self cleaning. What could it be.
The thermostat in the back of the oven is out. You'll need to remove the oven and remove sheet metal from the back to get to that thermostat. Part number 9759243
Don't forget to flip circuit breaker off before removing the oven.
And, yeah, if the thermostat is out, usually it means that there may be a problem with the oven blower or the oven is installed incorrectly.
Jun 02, 2010 | Whirlpool GBS307PRS Stainless Steel...
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Oven shutting off
To start with, F-1 is Failed Start.. When U hear the Beaping, U need to Push STOP, that will keep the Broiler from coming on.. Then put it back on the settings that you want. My Stove used to do the same, and it finally stopped doing it.. Hope yours stops...
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean on my oven and it stopped in middle of cleaning cycle
That most likely means there is a fault in the control board. You need to contact the manufacturer or retailer for service.
May 17, 2017 | Whirlpool GBS277PDS Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
653 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
