Question about Troy Bilt 22HP Hydrostatic 46" Riding Mower
There is an 20 amp fuse in the ground wire. This fuse blows each time you try to start engine only the selenoid will click. Have replaced selenoid, key switch, battery checks good. Ready to find a box of matches! HELP, HELP,
3 Suggested Answers
  • 302 Answers
SOURCE: My troy-bilt 13036 blows 20amp fuse after 15 - 20
Sounds like that circuit there is a bare spot in the wire and when it gets jarred around the bare spot contacts the frame in turn shorting out the fuse and blowing it.
Posted on Jun 30, 2010
  • 183 Answers
SOURCE: troy bilt pony will not start. replaced 20 amp fuse and battery
OK -- Here's what to do:
TROY-BILT PONY LT CRANKING CIRCUIT TROUBLESHOOTING
NOTE 1: The following tests are to be made with the parking brake applied and the PTO disengaged unless otherwise specified.
NOTE 2: These tests need only be made until the cause of the problem is located. The entire process need not be completed if the problem has been resolved.
NOTE 3: Refer to the wiring diagram below for understanding of all tersts.
NOTE 4: Wiring Diagram references to Key switch A1 and L terminals refer to the same terminal.
1. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the battery positive terminal. The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 2.
b. If YES, go to Step 3.
2. Connect a DC voltemeter directly across the battery. The voltmeter should read at least 12.6 VDC.
a. If NO, charge or replace the battery.
b. If YES, check and repair/replace the following items as required, then repeat Step 2 test. If YES on retest, go to Step 3.
-- battery negative cable condition
-- battery negative cable connections at the battery
-- battery negative cable connections at the tractor frame
3. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key swttch "B" terminal (Circuit #97 - red/white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 4.
b. If YES, go to Step 8.
4. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay BAT terminal (Circuit #94 - heavy red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 4 test. If YES on retest, go to Step 5.
-- battery positive cable condition
-- battery positive cable connections at the battery
-- battery positive cable connection at the starter relay
b. If YES, go to Step 5.
5. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder BAT terminal (Circuit #92 - red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 5 test. If YES on retest, go to Step 6.
-- Circuit 92 wire condition
-- Circuit 92 wire connection at the starter relay
-- Circuit 92 wire connection at the fuse holder
b. If YES, go to Step 6.
6. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder protected circuit terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 6 test. If YES on retest, go to Step 7.
-- 20A fuse condition
-- fuse holder condition
-- fuse holder wire connections
b. If YES, go to Step 7.
7. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "B" terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 7 test. If YES on retest, go to Step 8.
-- Circuit 97 wire condition
-- Circuit 97 connection at fuse holdser
-- Circuit 97 connection at key switch
8. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "S" terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 8 test. If YES on retest, go to Step 9.
-- key switch assembly
b. If YES, go to Step 9.
9. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #80 terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 9 test. If YES on retest, go to Step 10.
-- Circuit 80 wire condition
-- Circuit 80 connection at key switch
-- Circuit 80 connection at parking brake switch
b. If YES, go to Step 10.
10. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at
least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 10 test. If YES on retest, go to Step 11.
-- parking brake switch assembly mounting and adjustment
-- parking brake switch assembly condition
b. If YES, go to Step 11.
11. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 12.
-- Circuit 70 wire condition
-- Circuit 70 connection at parking brake switch
-- Circuit 70 connection at PTO switch
b. If YES, go to Step 12.
12. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 12 test. If YES on retest, go to Step 13.
-- PTO switch assembly mounting and adjustment
-- PTO switch assembly condition
b. If YES, go to Step 13.
13. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least
+12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 14.
-- Circuit 60 wire condition
-- Circuit 60 connection at PTO switch
-- Circuit 60 connection at starter relay
b. If YES, go to Step 14.
14. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay MOT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, did the relay make a single heavy "click" noise?
1. if YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
2. If NO, connect a DC voltmeter DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter relay frame. With the key held in the START position, the voltmeter should read a maximum of +0.1 VDC.
a. If YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
b. If NO, check and repair/replace the following items as required, then repeat Step 14 test. If YES on retest, go to Step 15.
-- starter relay mounting
b. If YES, go to Step 15.
15. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter motor BAT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 15 test. If YES on retest, but the starter motor does not engage, go to Step 16.
-- Circuit 93 cable condition
-- Circuit 93 cable connection at starter relay
-- Circuit 93 cable connection at starter motor
b. If YES, but the starter motor does not engage, go to Step 16.
16. Connect a DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter motor frame . With the key held in the START position, the voltmeter should read a maximum of +0.2 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 16 test. If YES on retest, but the starter motor does not engage, go to Step 16b.
-- starter motor mounting to engine
-- engine mounting to tractor frame
b. If YES, but the starter motor does not engage, replace the starter motor.
REFERENCE PART NUMBERS PER WIRING DIAGRAM:
Note that your specific tractor may use differnt part numbers. You can obtain a Parts List specific to your tractor online, at no charge, from Troy-Bilt at www.troybilt.com -- your full model number and serial number are required.
Key Switch 725-04228 (common alternatives are 925-04227B & 925-04659)Parking Brake Switch 725-1657A (common alternative is 725-04363)
PTO Switch 725-1657A (common alternative is 725-04363)
Starter Relay 725-04439
Also note that the starter motor is an engine manufacturer supplied part.
Posted on Jul 20, 2012
2006 Mitsubishi Lancer, gauge fuse keeps blowing. Have replaced the fuse twice, first time it was fine for a week but now it blows after a few minutes of driving...anysuggestionso
I would normally say to replace with a higher amp fuse, from a 15 to a 20. But it's possible you have a short somewhere in your system, grounding a power wire. A higher amp fuse could cause that grounded wire to overheat and burn making smoke. First thing to do is to check the ground wire(white)where connected to the firewall under dash and make sure they are clean and tight, for a good connection. The power may be backfeeding and causing the fuse to pop because of a week ground.
Dec 01, 2014 | 2006 Mitsubishi Lancer
New fuel pump, ccrm and fuel filter and still blowing 20 amp fuel pump fuse
If the components are all good, then check wiring connectors and wiring circuits, it appears the problem is after the ccrm. wiring from ccrm to fuel pump. For testing you should be able to use jumper wire with inline 20 amp fuse, from voltage to fuel pump connector, to see if it will run w/o blowing the fuse. As you can see from ccrm to inertia switch there are two connectors. From inertia switch to fuel pump, one connector. There are many ways to test. With connectors unplugged, you could use a test lite connected to battery voltage, touch correct wire terminal, if lite comes on, that circuit is going to ground, somewhere.
See that one wire that goes down, wire circuit from ccrm to inertia switch, that wire goes to pcm, I believe it to a monitor circuit, the pcm monitors the voltage on that circuit.
Aug 01, 2017 | Cars & Trucks
98 Town and country won't stay running, ruse keeps blowing.
Keep installing a larger fuse & you will
someday burn a car to the ground
If a fuse blows once there is a reason
Replacing it one time seldom makes for a fix
Aug 11, 2013 | 1998 Chrysler Town & Country
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have Exmark 52 LazerZ with Kohler ch25 engine. Engine stalled in heavy grass. Tried to re-start; engine turned over several times at lower RPM but stalled almost immediatly (PTO switch disengaged &...
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Jul 16, 2009 | Ford Tractor 8n Front Emblem
1999 Hyundai elantra died while driving found ecu fuse blown replaced lasted half a mile and blew again
Check your o2 sensor harness. The harness if not properly secured will rub on the axle to a point where it rubs through the insulation of the wire & shorts on the axle causing the ECU fuse (20A) to blow. Repair the harness & replace the fuse & bada bing! You should be in business! Hope that works. IF NOT follow this K.I.S.S.
Keep It Super Simple! It never fails!
Jun 04, 2009 | Hyundai Motor 1999 Elantra
30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Apr 12, 2009 | 1996 Hyundai Accent
Troy Bilt 22HP Hydrostatic 46" Riding Mower Logo
286 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
