Question about Breadman TR800 Plus Bread Maker
My bread machine pan is really badly scratched up, and resolutes to very bad dough and very bad bread. Is their a way that I can just buy a brand new pan or do I have to buy a whole new bread machine?
SOURCE: Bread pan jumps off of its fastener clips.
i have the same bread machine and sometimes it has the same problem. my solution is to take the pan out and place it back as deep as possible. i even made a little mark on one side of the pan and it's always on right side when it's in a machine. but the rule is to place the pan deep. sometimes it just looks like deep enough but not really. hope it'll help.
maria.
Posted on Apr 24, 2008
I have the answer to the TR2500BC pan popping off the base!! My husband and I made a loaf for testing the jump off. Ah HAH! I set the pan in, ok. felt it was down all the way. When it started to knead the ball and stop to reverse...it popped off. We looked at the side hook on top. ok. It popped off again. It was when my husband made sure the two tabs on the under side of the pan was in the opposit direction of the two buds in the base. at that point you MUST set the pan down with force until you get that distinctive click, click. Rock the pan front to back a bit as you push down. It has worked every time since I started that process. I make two loafs of bread a week with no problem of it hopping off. ENJOY.
Posted on Jul 20, 2008
  • 25 Answers
SOURCE: TR2200 bread pan, part number 22399. How much?
use oilve oil and reset the seal also you can use peanut oil it has a high heat range or wok oil also
Posted on Jul 24, 2008
  • 25 Answers
SOURCE: West Bend Bakery Style Bread & dough Maker
west bend site.
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=54&linkon=category
SOURCE: WEST BEND BREAD & DOUGH MAKER MODEL #41028
For all West Bend Bread Maker Replacement Parts, and manuals go to:
Posted on Dec 14, 2008
Do I need to spray the well of the baking pan
No, not a good idea as that is where the heat is. You will just make a burned on mess. You only spray the inner pan where you put your ingredients.
Apr 23, 2016 | Kitchen Appliances - Others
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
I am getting bits of pieces of silver flaky looking stuff in my bread dough. What is this - stuff from the paddle? The machine is making a high squealing noise?
That is probably the nonstick coating coming off the paddle or your breadpan or both. Are there scratches in your pans or paddles surface where you can see the metal under the non-stick coating? If yes, that is probably what you are seeing in your bread. I would tell you to try to get a new pan and paddle if they are scratched, but if your machine is squealing too then you should try to get a new or good used machine as you would end up spending more on the pan and paddle plus repairs to end the squealing, so you should just replace your whole machine. I have some models that are like new if you are interested in buying one. I would have to go through ebay and sell the almost new/new ones for $40.00 including shipping if you are east of the Mississippi. If you shop on ebay you can get one from me or of course others sell them there too.
Oct 20, 2010 | Breadman TR2200C Ultimate Bread Maker
Defective
Hi, the seals can not be replaced. You will need a new bread pan. If under warranty you can get pan replaced. Sorry Hank
Mar 28, 2010 | West Bend 41090 Bread & Dough Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
I managed to scratch the loaf pan and am looking to buy a replacement for my Tr520 Breadman breadmaker. Not proving to be very easy. Help!
Check out ebay. They seem to be expensive....For some reason I think the manufacturers don't sell the bread pans separately so you have to buy a whole new machine.
http://cgi.ebay.com/NEW-Breadmaker-Bread-Machine-Pan-Breadpan-TR875-TR520_W0QQitemZ380140130482QQcmdZViewItem
Hank
Aug 31, 2009 | Breadman TR520 Bread Maker
Need to make gluten-free bread
bobs redmill gluten free mix for bread machines. we just use the standard bake setting but select B for doneness level. found it gets a little too dark on A.
Mar 20, 2009 | Toastmaster 1183N Bread Maker
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Breadman TR800 Plus Bread Maker Logo
203 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
