Question about Dacor RV36SS Kitchen Hood
Vent will not retract - Dacor RV36SS Kitchen Hood
  • 2,382 Answers
Hi, first of all check the fuse on the circuit board.
If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced.
If this is not the issue then it is very possible that there is poor electrical contact between the Touch Pad and the Contact Board. Before replacing the Keypad Assembly check for a foreign material between the Touch Pad and the Contact Board. Examples of foreign material include grease, cooking residue, moisture, or residue from cleaning agents. Circuit board cleaner or equivalent (available from electronic supply stores) should be used to clean the keypad assembly. To diagnose the keypad: 1. Disconnect the Keypad Molex plug at the Main PCB and attach leads of an Ohm meter to pins #12 and #13.
2. Push the UP/DOWN button. This must show a closed circuit If the above test does not show a closed circuit, perform the following. - Check for grease or any foreign material between the Touch Buttons and the contact board. Clean with an electronic contact cleaner as described above. - Repeat test above. - If the contacts are clear, replace the keypad assembly. - If the circuit is closed, check for 120VAC between contacts N3 and L3 on the main PCB. If voltage is not present, replace the main PCB.
Posted on Nov 14, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Why does a/c quit blowing out of vents under heavy acceleration?
You may have a vacuum leak in the system. The vent doors operate under vacuum from the engine. There is usually a vacuum "tank" under the dash that stores some vacuum to keep things stable under such acceleration conditions, since engine vacuum drops very low during those times. If there is a leak in the system somewhere, this vacuum bleeds off too fast and the blend door will retract to the default position, which is normally to the defroster vents. Once you get back to normal driving, the vacuum recovers, and the door will go back to where you wanted it.
Oct 26, 2015 | 1998 Dodge Caravan
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Porter cable 15ga finish gun pin doesnt retract after firing
Porter cable uses a rubber band around the cylinder as check seal to push cylinder up. Pull cylinder and make sure that the band is place around series of holes in cylinder (about center of the cylinder ). If the band is in place then check for too much air leaking out of the nose due to worn/cracked bumper or lower bushing (washer with slot). If bumper and lower washer good, suspect debris in head vent preventing air form excaping or the shaft if the driver is bent (easy to check, driver should be easy to push back up from down position). Good luck
Jan 21, 2013 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Hammer doesn't retract
Assuming there is no air leaking from the gun, the check seal (part #175520) causes piston to retract. It is a band that fits around the cylinder and covers vent holes in cylinder. You can use orings in place of band (or be creative). Other reasons for piston not returning to top include bent driver, worn piston oring, or cylinder/ oring lacking oil. Good luck
Sep 04, 2010 | Stanley Bostitch F28WWMCN 28° Industrial...
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
May 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Vent doesn't rise
See this link for information on this.
Raise the Vent
May 23, 2010 | KitchenAid KIRD801HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Kitchen Ranges Logo
130 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
