Question about Haier HVF020ABL 20 Bottle Capacity Premiere Edition Wine Cellar, Black Cabinet with Silver Trim, Dou...
I received a Haier Thermoelectric Wine Cellar model HVTS16ASS as a gift a week ago. It was working fine until today when I can't get the temp to go below room temperature. I've unplugged, moved plug to new outlet, reset temperature, checked that door is snug. Fan is running. Outer cabinet is cool to touch. What else?
huuum
  • 750 Answers
SOURCE: Haier HVT 12ABS fan runs, but fridge does not get cool
Hello warmfridge
happy to assist you,
You said,
We've had this wine fridge for about 3 years now, and all of a sudden it stopped getting cold. We still hear the fan turn on and all appears to be running smoothly but it remains room temperature inside. Does anyone know how to fix this? I have no experience, but would like to try rather than buy a new one. thanks!
1. You may need to add freon.
2. It may have a faulty thermostat.
It seems you need hands on service!
Our site has good companies in the repair directory.
Bless you,
please rat me here before you sign off.
Thank You
Posted on Sep 14, 2008
  • 7 Answers
SOURCE: Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
  • 6 Answers
SOURCE: Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Posted on Sep 15, 2009
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
I have a wine enthusiast Model 2720206 and I don't know how to set the temp?
The answer is partly incorrect. This type unit DOES NOT USE freon as it is thermoelectric utilizing a heat pump. Unfortunately, part of the answer is correct. It likely will cost about $100 to "ring the door bell".
Sep 19, 2013 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Where is the main power relay?
the current is running in the wrong direction here is a site that shows how thermo cooling works.http://www.activecool.com/technotes/thermoelectric.html
Apr 22, 2012 | The Cellar : Thermo-Electric Wine Cooler -...
Model # HDWC35 Wine Cooler is not cooling at all.
Thermostat failure in those is very common. One quick test is to bypass the thermostat. And if it runs, you need to replace it.
Dec 12, 2010 | Avanti EWC28 28-Bottle Thermoelectric Wine...
I need a circuit board for a Haier thermoelectric wine cooler model no. HVW12ABB Part no. GCH-A11
My Kenmore mini Refrigerator has this same board. One capacitor has popped its top.
Oct 07, 2009 | Haier HVW12A Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Haier Wine Cooler won't cycle on and off automatically
If all you are doing is messing with that relay and then it hits the right temp, change the relay. I think the failure is a coincidence.
Dec 21, 2007 | Haier BC112G Wine Cooler
Haier HVF020ABL 20 Bottle Capacity Premiere Edition Wine Cellar, Black Cabinet with Silver Trim, Dou... Logo
106 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
