Question about Harman Kardon Audio Players & Recorders
Speaker setup i have a hp media center deaktop,windows xp, which came with a harman/kardon speaker system. Four speakers with a subwoofer. I need a setup page since the computer was moved and i dont have a clue. can you assist me , please?
  • Jimix Eouex
    Jimix Eouex May 11, 2010
    Is the wire length of your speakers not enough to reach your computer?
    Problem Solver:
  • 10 Answers
This is a hard problem when one is not looking at the speaker. But let me give you a little help if I can.
Try pluging the subwoofer into the speaker port of the Pc
Make sure your pc is turn of.
2) I believe the subwoofer has four jacks at the back.
3) Plug each of the speaker into the jack that says speaker
4)Now, if you are confuse of the in and out, on the subwoofer I understand. I believe you should be from out of the subwoofer to the in of the speaker. again, I cannot see at the back of you subwoofer.Only speaker from exprience.when you are done, turn your pc back on and turn the speaker on. making sure the volum is turn low.
good luck
Posted on Jun 19, 2008
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
Nov 26, 2015 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Do i need a satellite cord for this harman kardon to work properly
You shouldnt need a satellite cord. If the HK 12 has parallel L and R inputs and outputs, you should be able to run sound into the sub, and then out to whatever speakers you have. Assuming they are not a part of a sound system, and you are running 2.1 stereo.
Mar 19, 2011 | Harman Kardon HKSUB 12 Subwoofer
My wife dropped one of my harman kardon sound sticks and the top row of small speakers have dislodged how do i fix this as they dont seam to open ??
Find some adhesive such as Liquid Nails or Gorilla Epoxy and put a small amount on the speaker that has become dislodged. Make sure that the area where you put the adhesive will come in contact with the rest of the speaker tower.
Mar 01, 2011 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Are there Windows 7 (64-bit) drivers for a Harman Kardon HK695 speaker system? The speakers were originally purchased for a Windows XP desktop computer in 2002; and, I want to put them on a newer year...
They are speakers and therefore do not require a drive, well, I have never seen speakers that require one anyways. Your sound card is what needs drives but as long as you have the right connection (3.5mm jack) to plug into your speaker port the speakers should just work. If you need a specific program for advanced controls of the speakers then I would recommend going to the manufacturers website for downloads.
Feb 03, 2011 | Harman Kardon HK695 Computer Speakers
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
How can I get my Harman Kardon Soundsticks 1 to work on my PC?
The USB version of the soundsticks was specifically designed for the mac and they worked just by plugging them in and then telling the system to use them instead of the analogue outputs. Unless someone has produced drivers for Windows XP for these speakers I think that you will probably not be able to use them.
Jul 23, 2009 | Harman Kardon SoundSticks Computer...
No sound from my harman kardon speakers from imac
Has a speaker system ever worked on the iMac or is this the first try?
Does its onboard speaker work or is it muted? I'd start with some basic setup procedures.
Apr 05, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
291 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
