Question about Polaroid TDA-03211C 32 in. LCD HDTV
Power on no picture only sound - Polaroid TDA-03211C 32 in. LCD HDTV
    Problem Solver:
  • 5 Answers
Here is a solution for the problem. My tv did the same thing. You have 2 blown capacitors that are located at EC17 & EC18 on the top circuit board inside the set. On the back of your set is a black cover with 3 screws. One is in the middle and there are 2 small ones on each side. Remove the screws and the cover will come off. You will now see a metal cover and I think it has 4 screws. Remove them and remove the cover. You should now be able to see the inside of the set. There are 2 circuit boards. The top board has 6 screws I think and and 3 connections that need to be unhooked so that you can remove the board. You can order the capacitors at Digi-Key.com and the part number is 493-2069-ND. Look these up on the website and it will give you a picture of what you are looking for. I sent my board and the capacitors to a guy in Poland Maine at JD Electronics and he soldier them back in for me. I did not know how to do this. I put the board back in my set and it works fine now. Give him a call and see if he can help you. His name is John
(207)998-5687. I hope this helps.........Good Luck....Morton
Posted on Nov 14, 2010
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
At first, no power, no sound, and no picture. I replaced the power source board. I have power and sound but no picture.
verify your connections you may have the video cable connected to a different input than your audio
Apr 14, 2009 | Televison & Video
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
91 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
