Question about LG WFT1071TP Top Load Washer
I have an LG toploader washing machine Fuzzy Logic 6.5kg, WF-T652, and it has started to make a loud noise when it gets to the Spin Cycle. It is emptying the water, but then stops with a UE message. I have tried to redistribute the load as per the error msg, but the load comes out very wet.... any suggestions pls
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
SOURCE: LG WF-T1022TP Fuzzy Logic
Dear Sir¨
The problem with my machine WF-T1022TP is the fallow:
The pump not run correctly, for these reason, I need the manual of operation, please send this document to my e-mail: jmar440@gmail.com
thank you
Regards
Javier
Posted on Oct 04, 2009
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
watch the videos
Search Results
LG washer - Inner Tub Assembly replacement - Diagnostic & Repair ...
? 1:01
https://www.youtube.com/watch?v=vTKJFuKuUZg
Apr 30, 2015 - Uploaded by ApplianceVideo.com
WT1001CW LG Washer, Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos ...
ApplianceJunk.com - LG Top Load Washer Removing Bearing ...
? 4:17
https://www.youtube.com/watch?v=osTIeI7BIMI Dec 15, 2011 - Uploaded by ApplianceJunk
12:56. LG washer - Inner Tub Assembly replacement - Diagnostic & Repair - Duration: 1:01. ApplianceVideo ...
LG Top Load Washer Wash Plate Replacement #AGZ72909702 ...
? 1:39
https://www.youtube.com/watch?v=HBw4DvtrIjs Apr 11, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the wash plate on a LG top-loading washing ...
lg wf t652 washing machine remove drum Google Search
Apr 01, 2018 | Washing Machines
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
REQUIRES MANUAL FOR LG FUZZY LOGIC TOPLOAD WASHING MACHINE MODEL NO WF-T7030TP
The service manual is hidden inside the unit or inside the console.
Oct 22, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
120 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
