Question about Samsung HLN617W 61" Rear Projection HDTV
Flickering I have a Samsung HLN617W. After about two hours of operation it begins to flicker. As time goes on it flickers more & more. Then it eventually flickers constantly and creates shadows . Please advise
  • 54 Answers
Turns out it may be a problem with the Digital board, the A/V Board or the DMD board. Cost for repair (depending on which board it is) will run $400 - $1,000 or more.
or
replace the color wheel
definetily after this ur tv works properly.post me if further problem .
Posted on Jun 18, 2008
    Master:
  • 788 Answers
Since this is a DLP set there are multiple components that could be causing the problem, the hard part is determining which one.
My guess would be the lamp is beginning to die, which is normal, it is a light bulb after all. There is a guide here on changing the bulb: http://fixyourdlp.com/blog/2008/03/05/samsung-hln617w-lamp-replacement/
If you Google "HLN617W bulb" you will find multiple sources for purchasing a replacement lamp.
If it's not the lamp it could be something like the colour wheel motor, or the imaging board. But I would start with the bulb as other parts could be quite expensive.
  • 790 Answers
Hello mkarol001 !!
It might be something as simple as a loose scart connector on the TV, u have to wobble it around a bit or re-position the scart lead to sort it.
Regards
Smilemaker
    Master:
  • 638 Answers
Although the digital board could be a suspect, i would lean more to the dmd board. the board will hve to be repaired by a proper tv technician or it will lead to more critical state.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Flickering screen for Samsung LA40R81BHX/XSG
Resolder all of your boards ,Poor Solder Connections can cause this.
Jan 21, 2013 | Televison & Video
My samsung refrigerator goes off everytime the electricity flickers, even for a flash or less than a second. It goes off and it does not comebacks on for as much as 24 hrs. Sansumg's technitions says...
The fridge can cut off if there is a power flickering or variation as the relay will be energised to trip off. Once the fridge is off the self timer - 5 minutes- will be active to allow the gas/oil to come back to the compressor as the flickering would have produced an irregular pumping.
After about 5 minutes the processor will energise the relay to contact and start.
Now the main issue is the voltage in your household. if the voltage is low then the fridge will not start again as it will click and shut off. So make sure that there is sufficient voltage in the mains supply. Also the plug point where the fridge is connected must deliver good voltage/current as the wiring must be good to carry the load . If not the fridge will trip off whenever there is a power flicker.
Finall if the power is good then the fridge mut be checked as it cannot be off for 24 hours. register you complaint for warranty service.
If power is irregular use an auto- voltage stabiliser .
Aug 09, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Flickering picture when setting resolution to 1080P vs 1080I
This simply means that your TV isn't capable of handling a 1080 progressive input. This is why it is flickering. Change it back to 1080i(interlaced) and the only time you should ever see flicker is in a still menu. But even then it should be barely noticeable.
If your TV does support 1080progressive then you may want to change the scan frequency of the Yamaha receiver. Common ones are 24 frames/sec or 50/60 Hz. The amplifier should have an auto setting which will detect what the TV can display. The nice thing about HDMI is all that information is transmitted through the cable.
A version 2 or highspeed cable won't change the display at all.
Aug 11, 2009 | Samsung BD-P3600 Blu-Ray Player
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Jul 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Flickering
I would suggest to call Samsung to get the Plasma repair under manufacturers warranty. The flickering will not go away until the hardware failure is corrected.
Good Luck.
Apr 15, 2008 | Samsung HP-T5044 50 in. Plasma TV
Samsung HLN617W 61" Rear Projection HDTV Logo
117 people viewed this question
Henry  Thomas
Henry Thomas
