Question about Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
I have a schaeg BE365 and i would like to change the coad
  • 963 Answers
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
There is a video on this page, showing how to change codes.
Posted on Mar 06, 2011
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Need to change the 4 digit code be365-cam lost manual
Reprogramming BE 365:
This link will take you to the page that you need to get started:
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Aug 09, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Need to change lock code but lost instructions. BE365 PLY 716
This link will take you to the page you need, to get started:
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
May 21, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
How do you erase an old code and input a new code?
Programming info at http://dl.owneriq.net/a/a8480104-048d-488f-8efb-03836644d506.pdf
More manuals etc located at http://homeappliance.manualsonline.com/manuals/mfg/schlage/be365.html
If this helps pls leave feedback
Feb 05, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Hi the box super coads for n t l dublin
5401
bo b8 47 04 e6 5f 87 80 press ok
change key number 01
83 eb bc 07 d6 49 d2 eb ok
exit 3 times
happy xmas i drink cider
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
151 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
