Question about Porter Cable 19.2V Drill Kit
Model 8605 charger doesnt seem to work correctly, how can i tell if its the charger or the batteries?
    Problem Solver:
  • 20 Answers
Unfortunatly its probablly the charger, but the batteries can be checked / repaired @ your local hobby shop. They use the same cells for recreation / Hobby stuff
Posted on Feb 01, 2012
2 Suggested Answers
SOURCE: My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Posted on Oct 06, 2010
Afterreplacing house batteries in RV, magnum 2000 shows low battery fault although batteries are charged. Charger seems to work fine.
Are you sure you have batteries wired correctly? They still could be faulty, an have you tried to measure voltage on charger to make sure it's charging. An do you have correct charger for the type of battery your using.?
Jul 18, 2017 | Magnum Cell Phones
Charge light doesnt come on and camera doesnt turn on
Have you tried an external charger, with the same charger and the same USB cable?
If that also does not work, check the charger and check the cable.
Also chaco if the battery is placed in the correct way and can make contact with clean and shiny contacts.
Nov 20, 2013 | Nikon Coolpix S3300
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
Jan 02, 2013 | Porter Cable 19.2V Drill Kit
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
The charger doesnt seem to work, why is this?
Try taking a closer look inside the whole where the tip of the adapter slides in.. Make sure that the Pin that slides into the middle of the adapter tip did not break off or missing. If it is there, make sure that your battery is not the issue instead and/or you are purchasing an incorrect ac adapter.. Good Luck!! Lucky4lynn2
Mar 02, 2010 | HP 2133 Notebook PC
I have a toshiba labtop but i can't seem to remember the model, but i was working on my labtop and then the charger stopped working and wouldn't charge my labtop, ive tried 4 different power outlets but my...
how old is the laptop/battery? rechargable batteries sometime with age; I'm told, over time lose their ability to hold a charge. As far as model number number, usually at the bottom side on the sticker you can find all information you need.
Aug 22, 2009 | Computers & Internet
Not Charging?
if you have tried several chargers and it doesnt still charge then it could be a battery problem you could try replacing the battery but before you do this has the phone been dropped or got wet check where the charger plugs in and make sure there is no bit of fluff or paper stuck in the hole where the charger goes sometimes the chargers pack up but if not the charger then it is the battery that needs replacing hope this is somr help to you
Nov 17, 2007 | Nokia 3100
Porter Cable 19.2V Drill Kit Logo
817 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Steve P
Steve P
Franco Pinto
Level 1 Expert
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
