Question about Samsung HL-R4667W Rear Projection Television
I am trying to install a new color wheel for Samsung DLP model HLR4667W(AX/XAA). I have an L6 Chassis and was shipped part BP96-01103A. For some reason it is just not fitting correctly. The code on the actual replacement part itself is LC BP61-01024A#3. The old and new wheels look pretty much the same although there is more rubber around all of the edges of the old part. The old part is marked with AZ91D 1270-979 if that means anything. When I go to insert the new wheel, it will not go flush to the housing. It seems that something is keeping it from fitting all the way in. Any suggestions other than calling a service tech.
  • 208 Answers
SOURCE: samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Posted on Feb 21, 2008
  • 208 Answers
SOURCE: Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Posted on Apr 07, 2008
SOURCE: adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Posted on May 24, 2009
welcomejee
  • 10594 Answers
SOURCE: Color Wheel installation
You can purchase color wheel of Samsung HLT5075SX from Part Store and I would recommend to have qualified TV tech for installation. it is not advised to novice to get involve in such kind of repair that can damage TV.
Still you want to repair it by yourself then download service manual copy of same TV from HERE for small fee that has proper info.
Posted on Aug 05, 2009
SOURCE: Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Posted on Oct 09, 2009
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
Samsung HLR5078 50" tv - replaced a shattered color wheel but the colors are way off with the new one - yellow in place of both red and greens.
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Nov 11, 2014 | Samsung Bp96-01103a Dlp Tv Color Wheel L6...
L3 or L6 chassis?
The chassis number for this DLP should be printed at the back where you will find the model number and manufacturing date code as well.
Feb 08, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung Model HLR4667WAX/XAA is making a buzzing sound
It is likely the color wheel motor making noise
Check this link
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
If it helps be sure to vote/rate me Thanks
Oct 06, 2009 | Samsung DLP HL-P5663W 56" TV
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Part number for color wheel
That model is a plasma TV? Plasma TV's don;t use color wheels. Only the DLP sets do.
Aug 15, 2009 | Samsung Televison & Video
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
Dec 29, 2008 | Televison & Video
Open Questions:
See all Samsung HL-R4667W Rear Projection Television Questions
Samsung HL-R4667W Rear Projection Television Logo
741 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
