Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
I think my magtag refrigator compactor went out how long are they under wattarny?
How remove stuck compactor from under counter?
Thee should be two screws from the compactor going into thE countertop. (You have to get a light, then shine straight up under the countertop. Remove the screws, then you can slowly work the compactor out of the hole so you can work on it.
Jul 03, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Gaffers and sattler parts
go to qppliqnceparts.com and I think you can order it there
May 22, 2014 | Kitchen Appliances - Others
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor will not close and latch. I removed the trash bag and installed a new one then closed the drawer like normal, only drawer would not stayed closed. It just bounces back out.
you will need to remove the entire Drawer to see if somthing fell behind inside.
Most of the time you can pull the drawer all the way out and lift the front of the drawer and pull it out.
Feb 21, 2010 | KitchenAid P Series Trash Compactor -...
Whirlpool Compactor: starts making banging noises....
it sounds like there is something in the motor or a gear is getting ready to go out i suggest calling ge if it under waranty
Nov 15, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Freezer dethawed
By the end of the day we realized we thought the refrig. part was working but was not. We pulled it out from the wall, unplugged and plugged it back in. Still no results. I unloaded everything from the freezer in the morning and refrig in the evening. Right after I got almost the very last item out, (the door on the refrig was opened and left opened) I moved the temperature control levers back and forth quickly, really just out of frustration, thinking, 'great no more refirgerator' - now what am I gonna do?!. i went to dump the last of the contents, and like some sick joke, the refrig started working and then the freezer. We have quite a bit of dust under the refrig. that may have been blocking a fan or something. I think God just wanted me to empty the refig contents and things that looks like pieces of the moon from my ridge. Go figure. I am praying no more problems.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
