After installing Norton System Works 08110 i have been having trouble connecting to the internet, printing anything, fax trouble, modem not showing up. Restore System from windows does not work either. It was all fine before I downloaded nsws08110.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 65 Answers
As security point of view norten is very good antivirus...
but using norten creates many problems...
like slow down ur computer,error in running some programme etc....
i prefer u insteadd of using norten u should use kaspersky or simply avast is also good.....
unistall it properly and install n other nty virus...
then u r able to solve ur problem...
Posted on Jun 18, 2008
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Internet speed dropped after i reloaded my pc
Hi Dear. Is dialup connectivity fix to 28K every time you connect?
IF YES> Roll back and re-install modem drivers.
IF NO> Check your telephone line quality.
Apr 15, 2009 | Intel Advanced V.92 Data/Fax/Video...
Network connection prompt error 6: handle is invalid
Hi glamredhel, Norton has removed the virus or Trojan & if you have windows system restore turned on the virus or Trojan will return once the system has re-booted. Open windows device manager & shut off system restore. Re-boot your system & re-scan your system with Norton. In your case Norton did not give you instructions on how to remove the virus. (Norton did that for you).
Once completed check windows update service for a possible update for your LAN. Asus does not have a separate LAN driver listed on Asus web site. The LAN driver is part of the chipset drivers. Remove your modem from the system & any software you installed with it. (If any). Restart your system. (If the system seems fine-good. Shut down the system & re-install your modem & any software. When completed do another windows restart. See if the modem functions (If your modem is either a cable or DSL reset it.
Shut down the system.
Located on the back of the cable modem or DSL modem you will find a tiny re-set button. Unplug the power cord from the modem. Take a pen & press the reset button for 10 seconds. Re-connect the power cord & boot the system. Check for internet connection.
The above are just a few item you should try.
Good luck glamredhel!
Post your findings.
Mike
Mar 23, 2009 | ASUS M2N-MX Motherboard
Configuratin of Winfax pro
You need a fax modem. If you only have internet connection, you will not be able to send or receive faxes unless you subscribe to an internet fax service called www concordfax.com
Jan 12, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
Have to reboot PC before receiving faxes
check the firewall setting of norton
Nov 11, 2008 | Computers & Internet
WILL NOT PRINT
when it's asking for fax modem means that the printer is trying to connect somehow to internet (to connect to the homepage of dell probably) ..easy to get rid off this ..but first is the printer correctly installed (is it shown in your printer's folder (start>parameters>printers) ?
Aug 15, 2008 | Dell Photo 964 All-In-One InkJet Printer
Norton Internet Security is blocking my Internet connection
is your modem or internet connectivity allowed by the Norton Internet Security Firwall.
Jun 16, 2008 | Norton Internet Security 2005...
Internet connection trouble
That particular modem was said to have intermittent thermal issues as told to me by a third level technician on the business side of my local provider. I finally just purchased a new DSL modem as thermal issues are basically a design flaw.
May 01, 2008 | Efficient Networks SpeedStream 5260...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
