Question about Bulova Watch
How to set my bulova/wittnauer watch with chronograph hands. I tried to read the directions something just isn't right.
SOURCE: Chronograph hand not resetting to 12 o'clock
don't know if you have this fixed or not yet, but this worked for me.
pull the crown all the way out. then press the chronograph start/stop button. the chronograph hand should tick forward every time (or every couple times) you press the button. I'm not sure if you go past 12 if you'll have to go all the way back around. but try not to.
anyways, when it's lined up, push the crown back in and then start the chronograph and let it go for at least a full minute. now when you press the chronograph reset button it should reset back to 12. hope this works!
Posted on Oct 22, 2007
ONECCO
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
escapement
  • 2334 Answers
SOURCE: My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Posted on Jan 04, 2010
escapement
  • 2334 Answers
SOURCE: Heuer chronograph second hands will not reset to
Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Posted on Jan 29, 2010
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
I have an accutron and i want to reset the my
No need to go to the shop as you can reset chrono hand yourself. Read manual and follow instructions. If you don't have manual, try this: Pull out crown and then push the button and hold it. If this does not work, try push and hold the button whilst other one is held pushed. In short terms - try to use as many different combinations as you can and you will find which way is right.
Jan 09, 2010 | Accutron Bulova Tahoe Chronograph 26B32...
I have a stainless steel wittnauer watch with chronograph and instead of being set on the :30 mark, it is set on the :01 mark on the stopwatch. i need it back to :30
Pull out crown and press and hold one of the pushers (depends on a movement model). Try till you see chrono hand moving and reset it by using correct pusher. Every time you try a different pusher - push crown in, then pull out and try again.
Rate me, please.
Jul 28, 2009 | Wittnauer Watches
Chronograph for Bulova 96R19 not working
As it had a battery change since it was new? If it uses a Miyota movement, it needs resetting after a battery change to restore the 12 position for the hands. It involves shorting 2 points on the back of the movement (needs back off).
Feb 15, 2009 | Bulova 96R19 Wrist Watch
Users manuel
The following provides access to a two page operating instructions document this document is titled "Watch Setting Guide".
To access the document you will need Adobe Reader (free)
If needed click the Get Adobe Reader button on the following link
http://www.adobe.com
Watch operating instructions
http://www.bulova.com/dynamic_repository/instructions/593W.pdf
There are some additional manuals that might satisify your needs here too (you probably want Wittnauer at the bottom of the page - includes the one above)
http://www.bulova.com/service/instructions.aspx
Jan 01, 2008 | Watches
Paul Jardin Chronograph watch
Follow this link and type in your model number on the right side of the page.
After typing in find now. Click on the underlined here and you should find your instructions.
Dec 30, 2007 | Bulova Millennia Motion 96B34 Wristwatch
Bulova Watch Logo
242 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
