Question about Sunbeam 2350 Stand Mixer
Sunbeam 2350 Stand Mixer beater gears are stripped
SOURCE: Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
Posted on Dec 16, 2008
greenspan
  • 1734 Answers
SOURCE: Need owner manual for Sunbeam stand mixer 2350
I didn´t find it with google. Maybe ask the experts from manualfox.com - if they don´t find it, it does not exist.
Posted on May 27, 2009
  • 44 Answers
SOURCE: Where can I find the Manual for Sunbeam Model 2350 350
http://www.sunbeam.com/ca/category.aspx?section=kitchen&cid=14
Posted on Sep 08, 2009
  • 110 Answers
SOURCE: What is the best stand mixer to buy for home use?
the best stand mixer is a hobart n 50 its a little expensive, but if you use your mixer all the time, its worth the investment, buy 6 to 8 sunbeams, or kitchenaids, to 1HOBART N 50. metalgears in transmission, and in planetary,all the others have nylon gears
Posted on Feb 05, 2010
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
What is the best stand mixer to buy for home use? My 4 yr. old Sunbeam Heritage Series 450 watt Mix Master has stripped beater gears. Before that it wouldn't tilt back because of a loose screw. I don't...
Jan 16, 2010 | Sunbeam 2351 Legacy Stand Mixer
Motor runs but beaters do not turn.
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Jan 13, 2009 | Sunbeam 2350 Stand Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Stripped beater gear
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Stand Mixer
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2350 Stand Mixer Logo
111 people viewed this question
Top Sunbeam Food Mixers Experts
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
