Question about InFocus ScreenPlay 4805 Multimedia Projector
Infocus projector won't turn on
I recently bought home with projector suspended from 17ft ceiling. It projects onto second floor media room. I cannot reach it without making arrangements for a very tall ladder. I used it on Saturday and don't remember if I turned it off. I can't read the model number but know it is an infocus. The unit's red led flashes three times intermittently. I cut power at the electrical box but it continues to go back to flashing when I put power back on. Will I need to somehow get my hands on the projector? Previous owners have not had problems and cannot even give me a model number. What should I do?
  • Anonymous Mar 27, 2014
    hi
    is there a way to find out a make and model of an infocus projector as they are on the celeing and hard to reach.
From the infocus_lp650 manual
Table 2:
Red LED Behavior Explanation
One (1) blink The lamp won't strike after five (5)
attempts. Check the lamp and lamp door
installations for loose connections.
Two (2) blinks The lamp counter hours have exceeded
lamp life hours. Replace the lamp and
reset the lamp hours counter.
Optional Accessories Part Number
Three (3) blinks The projector has shut down the lamp.
Replace the lamp. Contact Technical Support
for repair if replacing the lamp does
not solve the problem..
Four (4) blinks The fan has failed. Replace the lamp (the
lamp module contains a fan). Contact
Technical Support for repair if replacing
the fan does not solve the problem.
Five (5) blinks The projector is overheating. Check for a
blocked air vent. Contact Technical Support
for repair if clearing the air vents
Posted on Feb 18, 2009
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
I work at an elementary school and the multimedia projectors are hung from the ceiling (a suspended ceiling) in a wooden tray and hanging by chains. Is this a wise choice?
First suggestion is checking to make sure that the tray/chains are secure - that it's not going to fail at at a point of connection either at the ceiling or point where the chains fasten to the tray. The tray must be strong enough for the weight of the projector (most InFocus classroom projectors are not that bulky and heavy).
Hanging anything with weight from the suspension ceiling braces is not recommended. If possible, having the wire/chain continue thru the ceiling panel (a small inconspicuous hole can be made through the panel) up to actual ceiling joists or whatever material the ceiling system itself is fastened to is best & the most secure. I've used steel aircraft cable (available at any Home Depot or hardware store) in place of chain, partly because it only requires a small pencil-sized hole thru the ceiling panel, hardly noticeable.
Most hanging fixtures (theatrical lights, projectors, etc.) have a secondary/backup safety cable or strap system should the main fasteners fail. In this case, if the tray and ceiling connection is secure, a safety strap holding the projector onto the tray so it's not sitting up there loose or able to be knocked out at all should be used. This also will help keep the projector's aim aligned to your screen should something bump the tray, you won't have to readjust it. (See this link attached for an example of a strap securing a projector).
(In all cases, if you have a building or school district maintenance administrator or someone who's job description requires them to be aware of state or district safety regulations/OHSA rules, they should be consulted to make sure you're following any safety issues that may apply specific to your classroom/student needs.)
Mar 06, 2011 | InFocus IN24 Multimedia Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
Our image is projecting upside down
you have accidentally switched it to ceiling mode. you need to go into the setup menu and turn off ceiling mount. this should fix your issue.
Jun 02, 2010 | InFocus In2106 Projector
How can i flip the screen up side down on the projecter
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Infocus X10 projector overheating.
okay most people think well its not hot up there but truely it is hot toward the cealing. If its overheating on the roof mount try to use a wall mount instead.. If they have it running for 5 days streight then is something your not oding right here and that might be the mount.
Nov 10, 2009 | Sharp XG-PH50X Multimedia Projector
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Oct 21, 2008 | Compaq Microportable 2810 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
1,201 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
