Question about Maytag EPIC MFW9700S Front Load Washer
Drain wont drain on a epic washer where is the drain filter located at
    President:
  • 1,554 Answers
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
Posted on Nov 14, 2010
  • 1 more comment
  • danjanerowl Dec 24, 2010
    Solution 1 worked for me. First sign of a blocked filter is the smell from the machine no matter how may times you clean the system. The screws were the only problem because my machines are stacked and was unable to tilt the whole unit. I only installed one back in because I can see this is going to be a yearly thing to clean. I used a large cookie sheet to catch the water once the plug was pulled and only had a minor spill. This did pay for itself because in the filter was 4.28 in change. LOL
  • Dadto5 Dec 27, 2010
    Excellent, as you led me directly to problem. this took me 15 minutes, max, to correct. Wow was the drain ever plugged. Also, if your washer smells like a backed up sewer, clean this this filter, more like a trap, out.
    This procedure has 3 screws and one plug to un screw. Easy and effective, as I am sure you would pay someone over $100 to do this job that required one screw driver.
    Thanks fo Jahn27
  • john leo Aug 07, 2013
    Thanks for the tip. Washing machine would not drain, smelled horrible, I unscrewed the 3 screws took the cover off. The drain was right there, I unscrewed it drained the water into a pan. Took out the trap had $2.57 in change, 4 screws, 1 hair clip and other things. then tried to spin the impeller and it was stuck. looked inside and there was a rubber band. took a tweaser and gently pulled it out, Screwed the drain cap on and presto it worked. Thanks to everyone who posted you saved me a bunch of cash!
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
No I have a code 5d what does that mean on A Epic Z front washer
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 03, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washer will not drain or spin? I get a flashing F when it comes to spin or drain
Check the drain filter and pump . Remove the front lower panel and you will see the pump
Nov 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Filter clogged
If this is a Maytag Epic, you are referring to the drain pump reservoir. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Make sure you also check the hose that runs from the bottom of the wash tub to the inlet side of the pump. Small articles of clothing can become lodged here. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If the link does not work for you, copy and paste to your web browser. Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have a maytage epic front loader, its flashing F21-book says drain problem, How can I fix it?
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
566 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
