I can't find the drivers for megavision mv155ub tft monitor. Where do I look
    Scholar:
  • 79 Answers
Hi It's important to know that you havn't to install monitor drivers, its not necessary.
Best regards Fixya is the best
Posted on Nov 14, 2010
Tip
I have a megavision 19" flatscreen monitor. The color is all screwed up. It has...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Feb 13, 2008 | Sony SDM-HS73P 17" LCD Monitor
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
Where can I find a Megavision MV173 LCA01F "monitor to computer" connection cord?
Isn't it a VGA cable?(15 pins-3 rows of 5 pins,slightly staggered.There is a 15 pin D-sub connector(2 rows of pins)-usually for extending a joystick cord on a PC.
Dec 16, 2012 | MegaVision MV173 (Black) 17 in. Flat Panel...
Pix on screen for abour 3 seconds then goes away----green powere lamp flashes???? whats going on???
Did you try this monitor with another PC yet and also check the VGA cable?
Most failure in the LCD monitors are due to bad DC filter caps as you can see in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/
You may want to learn more here in details if you are going to do DIY repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | MegaVision Hyvision Megavision 191 19"...
The monitor goes dark within a few seconds of turning it on. Is this something that can be fixed or do I need to replace?
Try replacing the power cable. (assuming that the monitor has not lights when it turns off) After replacing the power cable if that doesnt work try a different outlet.
If there are lights try seeing if you can replace the data cable from the monitor to the computer. If that doesnt work then you will want to look into getting a replacement.
Mar 01, 2011 | MegaVision Hyvision Megavision 191 19"...
Power supply bad
Hi there.
have you tried changing the power cord you are using?
Nov 28, 2010 | MegaVision Hyvision Megavision 191 19"...
My monitor has a blue cast over everything!
Check all the pins at both ends of the cable and make sure they are seated properly, also try it with another PC to make sure it is not the PC video card problem.
Basic LCD monitor troubleshooting guide:
Sep 29, 2010 | MegaVision Hyvision Megavision 191 19"...
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
My monitor jitters
when u power up press F8 key then go to enable vga mode then set resolution to 1024*768 thne check .
Nov 14, 2008 | MegaVision Hyvision MV177 17" LCD Monitor
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
