Question about Philips Televison & Video
Philips bds424 stuck in standbye - Philips Televison & Video
Rm3804
Verify is you have 100vac at the outlet behind the refrigerator. If you do not then you need to restore power to the outlet. The refrigerator will stay in LP mode until it detects good shore power.
Jul 01, 2014 | Dometic RM2652 Refrigerator
Its stuck on standbye
If it is a few years old, the most likely cause is failing PSU (Power Supply Unit) capacitors. These are replaceable by a competent electronics repairer.
For a more accurate answer, the model number would help.
Mar 15, 2014 | Humax Televison & Video
Stuck in standbye
Check for bad capacitors in power supply; 2200 uf and 1000 uf close to the heat sink of the top of power supply.
Nov 26, 2011 | Samsung 50 in. Plasma TV
Philips 42PFP5532D/ MAKES THE NORMAL CLICKING NOISE WHEN YOU TURN IT ON . BUT IT CLICKS BACK OF AGAIN SO YOU DONT EVEN GET A PICTURE ALL YOU GET IS THE RED STANDBYE LIGHT FLASHING DO YOU NO WHAT THE...
philips tv's test them selves when turned on if something is wrong it shuts down you need a tech to determine your problem more than likely it is you power supply
Sep 18, 2009 | Philips 42PFP5332D 42 in. Plasma...
T.v will not stay on!
The SSB board will cause this if its the one am thinking it is cost of board if AVL 295.00, other cause of problem STKs convergence ICs STK392-560 Go by part number on STKs, they are big black ics.; 2 of them.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips freevent x50
try holding down the power button for about 5 seconds to make sure it isnt in standbye mode
Sep 18, 2008 | Computers & Internet
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
