Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
I just got a toshiba 51h83, that my buddy was throwing away.TV is in mint condition. Picture quality is good but no volume on any channel including all inputs and hd settings.Could a circuit board have gone and if so which board?
    Problem Solver:
If you have the original remote, go into the menu settings and see check the sound configurations. It is possible that your friend had turn off the tv's internal speakers so as to utilize a hometheater system.
Posted on Nov 26, 2010
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
My 15 year old toshiba projection tv that was hardly used. the screen now will not light up and on off button is blinking
Hello, I just received your email about your TV and will do a little research on it to give you a good answer to the problem real soon later today. Thank you Looks like a 51H83 model
Feb 17, 2012 | Toshiba 51H83 51" Rear Projection...
Rear projection tv blinks from good picture to not so good picture. Verizon has changed the box and says its the tv Model 51H83
the best thing would be to unplug then unit and then unscrew the back panel and the light box should slide out clean it with a duster or a air hose be careful if this doesnt work your lights are going out
Feb 25, 2010 | Toshiba 57H81 57" Rear Projection...
Model #KCL8806DT under cabinet tv- volume works fine -no picture on tv. Remote works with volume, will not chnge channels on tv. Channels will change if channel button on tv used. Menu button will not show...
the bad thing about your gpx tv is that it is made by apex and u cant get any parts for them they are a throw away units. now that i gave u some bad news now lets see if we can do anything to help u.u will not see a on screen menu if the lcd is not on ok. there is nothing u can do for this tv . it only sales for 70- $80.00 if the unit is under warranty u can send it back and get anotherone. i am sorry but when u buy and off brand unit this is what u deal with when it goes out.they donot make it so it can be repaired.
Oct 13, 2008 | Televison & Video
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
May 25, 2008 | Televison & Video
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
DS20930 TV
Sanyo makes a fine TV. You have a problem in the vertical circuit causing the line. You should not play the set in that condition because you can dammage the picture tube. Call a few local shops to get an idea of what they charge to fix a vertical problem on a 20" TV. If the cost of repair exceeds about 65% of replacement, toss it. In my opinion the newer sets are lacking in quality compared to older ones. In short , they break more often. If you choose to buy a new TV stay with a known Japanese brand.
Nov 29, 2007 | Sanyo DS20930 20" TV
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
220 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
