Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Hot point range - model #RG85080PA1WH
Oven does not stay lit below 400 degrees. And it keeps getting worse.
PLEASE HELP.
  • rictif Jun 19, 2008
    I don't know, since I have not consulted with a repairman or purchased the part yet.
  • Anonymous Mar 27, 2014
    Estate model TEP200VAQ
    Genius:
  • 2,028 Answers
It could be that it just needs to be cleaned. The oven burner may be clogged, or it could be the control valve. Try the cleaning first, if that doesn'd do it, then you will need a service to check the valve
Posted on Jun 18, 2008
  • 796 Answers
Your oven igniter has gone bad, even though it still glows, they just wear out and don't open the gas valve to ignite the gas.
Here is the one for your model:
Part#WB13K21 (http://www.repairclinic.com/referral.asp?R=1265&N=2494)
http://www.repairclinic.com/dbimages/00000578/00175428.jpgOven igniter assembly (http://www.repairclinic.com/referral.asp?R=1265&N=2494)
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Have a frigidaire wall oven that won't get to 400 degrees
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
Jan 25, 2015 | Frigidaire Ovens
Turned on oven to 325 degrees it kept heating till very hot and now oven will not turn off
Good Morning Friend,
I understand that your Frigidaire electric oven will not shut off. I also see that it gets very hot, way past the set temperature of 325 degrees. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. If further troubleshooting is needed, please leave me the model number of your range. Typically this number can be found on the back of the door or possibly in the bottom drawer. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
American range msd 1 wont stay lit
There is a flame sensor at the ignitor, you may want to clean it first and re-try see it help...good luck
Sep 04, 2012 | American Range Majestic M1GLP Stainless...
When I turn the oven to 400 degrees for instance the temperature doesn't go to 400 degrees and the top element is hot, not super hot and doesn't get red. It is a Whirlpool Gols, Acubake system. Model...
Hi
Thanks for using FixYa. This indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 14, 2010 | Whirlpool Ovens
Ignition not turning off once oven lit
It is normal for the ignitor to stay lit while the burner is going...There is nothing wrong there...
heatman101
Apr 07, 2010 | Ovens
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
MY XL44 GAS OVEN IS HEATING UP BUT IT DOES'NT STAY AT THAT TEMPERATURE CONSISTANTLEY. I HAVE TO SHUT THE OVEN OFF AND THEN PUT IT BACK ON PRE-HEAT.i NOTICE THIS THE MOST AT TEMPS BELOW 400 DEGREES. MODEL#...
Your model number is not showing to be valid, please double check it.there are a few differant issues you could be having.
  1. the bake ignitor is going bad and its on the edge of total failure
  2. the sensor may be developing a short in it and the odds of the short occuring increases the higher the temperature
you can look up the parts here http://lartoday.com/order_parts.htm using your model number
Levi
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 10, 2009 | GE Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
110 people viewed this question
Top Hotpoint Ovens Experts
Mike Cairns
Mike Cairns
bosch5
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
