Question about ASUS Computers & Internet
I plug the laptop in and it wont charge the battery that I just puchased if I unplug it it dies if i plug it in and take the battery out it dies I purchased a new 95W adapter same thing
  • slcomputer Nov 14, 2010
    It will stay on all the time if the battery is out of the NB. If I put the battery in it shows the electricals working but as soon as the battery is dead it shuts off with the AC adapter.
  • 2,567 Answers
Sounds that the power receptacle in your laptop is either loose or damaged. You will need to disassemble the laptop in order to re-solder it or replace it if it is severely damaged.
Please refer to the following article for more details:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Posted on Nov 13, 2010
  • Mohamed Omran Nov 14, 2010
    Then, this might be an indication that the laptop's charging circuitry on the motherboard is defective. This needs to be serviced at the component level, or you might need to replace the motherboard.
    If the laptop is still covered by warranty, better contact your dealer.
Laptop died out due to no charging.. but now even when its being charged, it wont turn on
The battery may have gone bad. Amazon is one of the cheapest places to look for a replacement.
May 08, 2015 | ASUS Transformer Book Flip TP300LA...
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
Battery Wont Charge Past 65%
There is a short-circuit happened at your laptop or the laptop charger.
Aug 12, 2013 | Computers & Internet
What will happen if the battery in your laptop is not fully charging
That would mean your battery is dying and you need to go buy a new battery for your laptop. You can buy new batterys for around $40
Find a store that sells laptop parts or go online look on amazon or next tag also when you get your new battery plugin your laptop charge your new battery so it has a full charge.Then when it is done charging unplug it and use the battery until it dies, then plug it in again to recharge it never leave it plugged in if it is fully charged for long periods.if you are using your laptop at home you can pull out the battery and use it when its plugged into the wall this will help to extend your battery life just make sure you have a fully charged battery before leaving your house. always unplug your your laptop when its is fully charged this will also extend your battery life for along time
Sep 26, 2012 | HEWLETT-PACKARD Hewlett Packard Battery...
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
My everex va250e wont charge or turn on!
Check the charger with a volt meter to see if the output of voltage is correct. The chargers specifications will be on it telling you the output range. If all checks out well replace the computers battery
Jul 17, 2010 | Televison & Video
Laptop was unplugged while still running ans now
This happens when the battery dies and there is insufficient detectable power to run the boot system. You must change out the battery with a fresh one, or plug in a good external power supply to get things started.
You may also need to let the internal battery charge a short time before the boot system sees enough available voltage to start all systems.
Dec 19, 2009 | Computers & Internet
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Computers & Internet Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
