posted by weertobal on Jun 18, 2008
every 20 or so seconds the machine gives a pop-up "No Fix" and starts to search for the satelites again and again.
Jan Weerts
1 Other User Has The Same Problem
Comment by niksuinc, posted on Jul 01, 2008
My EKP IV will stop working for some time and than start working again. When I stop for fuel it may start working after 5 minuits or even up to 2 hours. The factory asked me to send it back for them to check it, and put in a larger memory card.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 18, 2008
Hello weertobal,
Where are you using the GPS when this is happening? In order to get a fix on its own location the GPS receiver needs to receive telemetry information from four or more GPS satellites. In order to get this data, the receiver needs a clear view of the sky.
If you are using the GPS indoors, in an area with a lot of obstructions such as mountains, trees or tall buildings or in an automobile or vehicle without an external antenna, then your GPS may not have a clear view of the sky. This can cause it to be unable to get a fix on its own location or it may take a very long time to aquire a fix.
If the problem persists when you are using the GPS outdoors with a clear view of the sky, then this may be a sign of a more serious problem that could require service.
Best Regards,
Ken
"Go Ahead. Use Us."
Best Regards,
Ken
"Go Ahead. Use Us."
Suggest a new solution for this problem
Post a New problem for HandHeld Entertainment AvMap EKP-IV
Email this problem
Email this problem
Can you Help with these GPS Devices problems?
Repair Service
Find GPS Device Repairman Near You:
