Question about Eureka Smartvac 4870 Bagged Upright Vacuum
I need to know the correct belt for my Eurecka Boss 4870 Refurbished. Every time i put the belt on it brakes.
    Novelist:
  • 147 Answers
The correct belt for this machine comes in a package. It should be Eureka Style R belt. (61110-A)
Pic attached.
This is the correct belt. Anything else will just snap right away.
Good luck.
Posted on Nov 14, 2010
Vacuum squeals when running. Big boss smart vac 4870
most likely you have something trap in the blower fan. if not chech for some obtruction in the tube. a piece of paper or the like. also check you belt.
Feb 06, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
My 4870 K Boss is 2 years old. I have replaced belts & filters in the specified intervals. This last time I replaced the belt after a year, it shredded 3 of them on the outside edge of the belt in...
The only reason why it would be shredding the belt is if the pulleys were not lined up correctly. Check the allignement of the belt to make sure there is nothing kepping the pulleys from being in line. The other thing that it could be is if the roller was not rolling freely check the beater bar and make sure it is free and if not clean the inside of the end caps to be sure they are free of hair and other debris.
Feb 06, 2010 | Vacuums
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Any belts that can sub. for the RR
Applied the electrical tape to the motor shaft as suggested by another poster. The tape ripped off, but the sticky residue left provides enough friction to grab the belt and cause the beter brush to turn correctly. Thanks
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Mar 08, 2008 | Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
85 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
