Question about Siemens SpeedStream Modem (4100) (SS4100)
Installment help need to know how to install my modem that is not dialup
  • 72 Answers
Connect it to the phone line, connect the ethernet jack to the computer and plug the power cord in. That's the only "setup" a modem needs.
Posted on Aug 19, 2008
2 Suggested Answers
SOURCE: Agere All 56K Modem
I have checked the telephone line, it is working alright and it is sure that I have plugged the line into IN port.
Posted on Oct 19, 2008
How can I connect Compaq Presario 1266 to internet?
if you have ADSL connection, once you connect your computer to the modem, the internet should work right away given that the driver for your LAN is installed. if you're on dial-up, you need to coordinate with your phone company to configure the dialup connection, that is if they offer dialup internet service. hope it helps.
Mar 16, 2010 | Computers & Internet
How do i set my lg rumor to data/modem setting
1. Get GPRS activated on your phone number from your service provider. 2. Install the PC suite of LG on your PC. That means install the phones drivers. When you do this all drivers including that of phone ad modem will be installed. 3. Ask you service provider for the following info a) IP Address. b) Proxyport Number. c) Proxy Port settings. d) APN. And set then to your phone. 4. Connect the phone to the PC and allow Windows to detect the phone and load its drivers. 5. Go to Control Panel->Network Connections. 6. Setup the dialup connection for your phone modem. 7. Your service provider will also give you the number to dial from your dialup connection. Enter that in the dialup. 8. Connect. The connection will take around ten seconds. And you are on.
Nov 25, 2009 | LG RUMOR Cellular Phone
DSL-2640U connect to internet but want to setup second dialup connection from pc
Sounds like you have high speed internet and also want a dialup connection as well. Maybe as a backup.
Anyway, your pc will need have a dialup modem installed in it.
If you already have one installed then you will also need a dialup ISP account. Some times an ISP will provide dialup in addition to broadband. Ask you ISP or call AOL.
Sep 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a used compacq 530 but do not know what is missing because i cannot get it to hook up to the internet
Possibly if you gave more information .....does it have a network card installed, is the network card "enabled" in the hardware settings, does the network card have correct drivers ? ( no yellow question mark beside it ) Do you have an internet provider and account ? Is your internet high speed or dialup, if it is dialup, do you have a modem installed - with correct drivers ? Is it working - do a modem query to see if it responds ?
If using a network card and cable or DSL internet, is the cable connected from the PC to the cable or dsl modem ? Is the cable or dsl modem plugged in and the power and wan light on ? With the little bit of information you have given, it is not really possible to give an exact answer to what the problem is.
Aug 30, 2009 | HP Compaq d530 SFF PC Desktop
Trying to connect to dialup with acer laptop notebook
Right click My Computer icon and then My Properties. Click on the Devices tab and check hhe list for Modems. See if your modem appears and if is correctly installed (an exclamation point beside iyour modem, means there is an instalation error).
If everything is OK, you still have to setup the dialup connection:enter the phone number to connect , the username and password, supplied by your ISP provider.
Look here for a walkthrough:
http://209.85.229.132/search?q=cache:OIgea_RPOhEJ:www.learnthat.com/courses/computer/windowsxp/dialup/+dial-up+connection+setup&cd=2&hl=pt-PT&ct=clnk&gl=pt
Jul 22, 2009 | Acer Aspire One AOA150-1405 Notebook
Pci simple communications controller not found
That would mean you need a modem driver installed for that PC, or your modem is bad. Now this is refering to a dialup modem not a broadband modem.Goto Dell website and under support you can enter your PC moodel number and download the Communication Modem Driver. I have provided you a direct link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
If this doesn't help, seek out a repair shop and get a new modem installed.
If this helps please rate my solution.
May 11, 2009 | Dell OptiPlex 170L PC Desktop
I need to replace my Acer Desktop dial up modem. Can I do it myself and how?
Ok - Here is a picture of a motherboard:
I suspect your existing dialup modem is in an existing PCI Slot on your motherboard, remove the existing dialup modem and "snap" your new one in it's place.
Use the software that came with it to get the correct drivers to work on it, (though I do believe XP and Vista will install without special drivers), but having the correct one for the modem you put in will insure it's working properly.
Aug 05, 2008 | Acer Computers & Internet
How to install a modem in gx150
I really wouldn't bother with dialup anymore, you can get a broadband package for the same money.
if you must use dial up, to install a modem,   you can use an external modem which means you don't have to open your pc(invalidating any warranty).
if you really want an internal Modem you can get a PCI modem which can be easily be installed into a free PCI slot,
If your board has an AMR/CNR slot (a small slot specifically designed for modems/network cards) you can buy a modem for that slot (which does not use one of your PCI slots)
Oct 30, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Siemens SpeedStream Modem (4100) (SS4100) Logo
166 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
