Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Not as cold as it used to get, ice production is very slow, thermostat turned all the way up, could it deen to be defrosted
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Nov 14, 2010
No defrost light, icing up on Dimplex DXDH20
There should be a timer that turns on the heaters for the defrost on a schedule, That does depend on the age of the product, many newer units use a logic board for defrost. It also is possible that the defrost heater its self is defective. there are several components to the defrost system the timer, heater, as well as a thermostat to stop defrost heat when the thermostat is satisfied
Oct 10, 2016 | Refrigerators
Ice maker doesn't work.model kbfa25erss01
Hi and welcome to FixYa, I am Kelly.
Often when ice-makers stop working the real problem is that the freezer is not cold enough (It must be 14-16F for the icemaker thermostat to cycle) Check for signs of ice or substantial frost in the back of the unit / evaporator coil area. If you have ice / frost in this area you should do a manual defrost by unplugging the unit and directing an external fan into the freezer compartment for about 2 hours while it makes a water mess that will need to be tended too. Once the 2 hour thawing is complete wipe up the excess water and return the unit to normal service. If the problem was caused by excess ice it will operate normall for 2 - 3 days before ice production slows or stops totally. Should the manual defrosting correct the icemaker problem you most likely have and automatic defrost problem in the form of a problem with one of these 3 components:
1. Defrost control
2. Defrost heating element
3. Defrost thermostat
Having said all of that... You can use this manual to check out your icemaker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Make sure to test the coils on the inlet water valve for continuity. If one of the coils is open *** must be replaced. The inlet water valve is NOT repairable.
Your water valve can be found here:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-water-inlet-valve-item-number-ap4080917.aspx
Here is another link on how to test out the icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The ice-maker thermostat must be at or belw 16 F for the above tests to work.
NOTE the freezer door LIGHT switch must be taped down also.
Before you get too deep into troubleshooting checkout the freezer door light switch first. If the switch is bad the freezer compartment light will not work and the ice-maker also will not work.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | KitchenAid Refrigerators
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Kelly
Apr 16, 2011 | Kenmore Refrigerators
My two year old refridgerator isn't making ice as fast as it did before
Since the ice production depends on the temp in the freezer, your freezer may not be as cold as it use to be. Should be at least 10 degrees F. If you're having a defrost problem that would cause the temp to be higher than normal.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Dec 26, 2010 | Whirlpool ES5FHAXS Side by Side...
Temperature is set to high. no ice is being made and temp.is not cold on either side .could it be ice on the coil if so how can i fix it?
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Kenmore 5520 / 655202 / 55204 / 55209 Side...
Refrige and freezer do not get cold. Freezer is all iced up.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 16, 2009 | Refrigerators
Whirlpool Estate series fridge/bottom freezer no longer gets cold
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer not cold enough to make ice and fridge cool not cold
Aug 30, 2009 | Whirlpool Refrigerators
Defrost not working Getting ice buildup under cover and water under drawers in frigde department
This may be two problems. The water may be that Your drain tube is stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 29, 2009 | Refrigerators
Losing Cooling
manufacture/ model helpful. can you find timer???most newer refrigs use control boards. assummong you have a timer advance it to turn into defrost (turn real slow it'll click off compressor) is it really hard to turn(feel like its sticking or turn easy??? should be a smooth turn. If enterd defrost and after 2 min you still dont hear heaterkickin on . id ck defrost thermo. located on evaporator. when cold enough the thermo should test" closed" on an ohm meter and the heater should also be closed circuit.
Mar 06, 2008 | Refrigerators
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
71 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
