Question about Microwave Ovens
The touchpad has failed.... How can I fix it - Microwave Ovens
  • 3,051 Answers
HELLO THERE
hEY CAN YOU PLEASE TELL ME THE MAKE AND MODEL NUMBER SO I CAN GET YOU THE INSTRUCTIONS ON REPLACING IT
Posted on Nov 13, 2010
Sanyo microwave windmill super showerwave EM-3490W. TOUCHPAD NOT WORKING
The touchpad may have failed but a defective connection should be considered.
Sep 12, 2017 | Sanyo Microwave Ovens
Kenmore Elite Microwave model 88523 has failed 2 times with an error code of TE. Sears fails to accept responsibility for the manufacture of a defective product, instead put the blame on me for not p
make this test . God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
  4. main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  5. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Dec 12, 2013 | Microwave Ovens
Unit fails when attempting to cook.
see the steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jul 12, 2013 | Samsung SMH9187 Microwave Oven
Unit cuts off
see this steps and fix it. God bless you
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 03, 2012 | GE Microwave Ovens
Set clock but time goes off
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Maytag microwave keypad
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
