Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I have a Jandy Lite 2 - 400,000 BTU Pool / Spa Heater. Model # LJ400N w/ Touch Pad controls After a proloned period of non use, my spa was not heating. I removed the front panel of the heater unit. I manually turned off the heater then turned it back on, only 2 or 3 rows of the burner fired up after waiting about 20 seconds and then it shut right down after about 10 or 15 seconds. The unit won't ignite again until I manually set it to the "off" setting then turn the heater back on to "spa" setting again experiencing the same result with the heat exchanger only patially igniting and shutting down immediately. When it does light, the flame is a cool orange instead of a hot blue. There are no service codes displayed either.
  • timezone910 Nov 16, 2010
    The experts instructions where right on target! I folowed them and the unit fired right up! EXTREMELY happy!
    Sorry to hear about your bad day!!
    You have no idea how grateful I am for your help..
    You're diagnosis and instructions for the fix were absolutely flawless!! 100% on target!!
    My knuckles are busted up a bit from the job but I was sitting in my 102 degree hot tub tonight for the first time in a year!
    Thanks again..
  • 990 Answers
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
  • Kieran Ruppert Nov 16, 2010
    I just spent ten hours trying to run down an electric problem on a spa,to no avail. It was good to get home and find I had helped with your problem. Thanks for letting me know. I feel better now.
    Funny how the world works. It's way cool your tub is hot. NRN
How to retrofit a ingeniter kit
you can still get mini 4" ignitors if not get pentair mini max
Jun 04, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Ihave a 175000 btu Lite 2 Jandy Pool Heater model # LD175P. It takes approx 3 hrs to go from 48 degrees to 100 . Why so long?The spa is 7ft in diameter and normal spa depth.Should I have a more btu heater?...
That seems to be a pretty good heating rate. You're talking about 52 degrees in 3 hours. If you want quicker heating, you will need a higher output heater.
Gary
Jan 06, 2011 | Jandy Pool & Spa
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Getting error code 188E on Jandy Model LT Lite 2 pool heater. also control panel keeps flashing. Anyone know why
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Jun 06, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Jun 06, 2009 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
1,188 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
