Question about NAD T751 Receiver
I own the nad t751 and need to connect apple tv with optical wire but I am using this port for the DVD . Is there a workaround that a novice can handle?
  • 757 Answers
Yes. However, you will need an additional connection type. It is the coaxial connection for your DVD player. Just replace your existing optical cable for that connection with the coaxial connection (sometimes labeled on some players as "bitstream"). Then you can use the optical cable to the Apple TV.
Posted on Nov 14, 2010
Hi, nad going but no sound from speakers. can get FM but only up towards full volume.
Checker speaker wiring on back for shorts, if okay! the audio drivers and outputs are highly suspect, at this point I suggest a serviceman because of the complexity of the surround sound system.
Apr 20, 2012 | NAD T751 Receiver
I have a NAD C720BEE receiver and I'd like to get apple tv and run it through my stereo with this receiver. Can you tell me if this is possible. thanks, Letitia
You will be able to connect the apple TV to the Nad Stereo receiver. For that check the picture bellow of the apple tv box. There is two connector named Analog Wich you can connect to the input of the Nad. You can choose Video in put of the Nad. There is a need For a stereo RCA capble to interconnect both the apple tv and The NAD receiver. I have also added the picture of the RCA cable Which you need. After making connections Power on both apple TV and NAD. In the Nad receiver select Video in by Pressing the video button on its frond pannel.
Suarly you will get the audio.
If you need any more assistance feel free to contact me By fixya. Our you can conatct me on my email address ajingopakumar@gamil.com
Ajin
Mar 01, 2012 | Audio Players & Recorders
NAD T751 shuts down
There is a board between the front and the main transformer. It's connected to the front with a wide flat kable. There are some capasitors like C173, C174, C176 and C199 that usally dry out. There is also on capasitor on a small additional circuit on this board. This was the main problem in my case. It's 2,2uF/50V.
Dec 15, 2011 | NAD T751 Receiver
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
I am trying to hook up my home theater system
marvidson,
With the NAD model that you have and its lack of component or HMDI switching, the only way is to connect your system, sort of, backwards.
The only way to do it is to connect your digital cable box and blueray player directly to the tv, then the audio output from the tv to one of the video inputs on the NAD. The NAD has digital coaxial and toslink inputs so if your tv has one of them as an output, that would give you the best sound to the NAD. If your tv does not have either of those outputs, then you will be limited to the composite outputs (red and white) but that will still give you good sound.
Also, depending on the digital output to input configuration, you could possible find a converter online.
-Chris
Jan 19, 2010 | NAD T751 Receiver
My front display is burnt out on my NAD T751. How do I fix this?
Usually the problem is not that the display is burnt out but the voltage that supplies the filament is missing due to bad solder contacts on the terminals of the display.
If you disassemble the unit so you can see where the display assembly solders into the board check/resolder those terminals.
Oct 19, 2009 | NAD T751 Receiver
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
NAD T751 constant buzz
It is a known problem with this model. The source of the buzz is the Dsp power supply. On the DSP board itself there is a 2200my\f/16v capacitor that is defective . Usually the capacitor will turn brown and swells due to overheating. Replace it with a higher temp rating capacitor with the same capacitance and voltage specifications.
Sep 26, 2008 | NAD T751 Receiver
Open Questions:
NAD T751 Receiver Logo
168 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
