Question about Briggs & Stratton Gas Pressure Washer 20244
Engine will not start. It has not ran in over a year I changed the gas, I changed the hose from the tank to the carburator it was bad the air filter looks okay and I have changed out the plug and it still will not start.
  • 520 Answers
If you have spark the its a fuel problem. i reccomend a product called START. walmart sells it it is amazing it cleand the varnish and gunk in the carb. their video shows starting a chainsaw with 3 year old gas in it. i use it and swear by it.
Posted on Nov 13, 2010
On Honda 2009 Shadow Aero, Engine "bogs down" at top of throttle. I've cleaned gas tank, carb, fuel line.
Have you cleaned the carb power jets and blown them and there passages out with compressed air?.
Sep 13, 2016 | 2008 Honda ST 1300
Has ran perfect for several years now it feels like it has a misfire .
it sounds like you have got water in your tank I would change the fuel filter and put 2 little bottles of gas line antfreaze in your tank
Jul 11, 2015 | 1996 Saturn SL
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
My air compressor will crank and run for 7 to 10 minutes and then die just like you turn the key off.
well you didnt mention what year or model number you got but some of the better IR compressors have a fuel saver mode that if they don't sense any change in load for like 15 minutes they shut off could be what your seeing , or could also be a safety sensor on the seperator tank not seeing any pressure build up (bad or damaged sensor?)
Apr 15, 2014 | Ingersoll Rand Air Tools & Compressors
1987 Ecoline van V-8 engine hasn't been started in about 7 years. It ran good before that. What do I have to do first to start it and get it running?
I would change all the fluids and either try dry gas or i would recommend that the gas tank be thoroughly drained and new gas put in the tank.If you have a hard time getting started try to use starter fluid in carburetor or if you have none just use gas. If the vehicle is equipped with fuel injectors locate air filter and follow air duct to engine that is where starter fluid or gasoline will have to be pored to prime the injectors.if it don't start the engine should be tuned up with a major tune up replace all filters ect even if it starts without tune up i would tune it up asap!
Aug 21, 2010 | 1987 Ford Econoline
I have a Subaru EA81 1.8 l engine in a boat. Ran fine for years. Lately it has been giving me problems. It misses, especially when up to operating temperature (~175 degrees F). When up to that...
the first thing to go wrong with any petrol(gas)engine for marine use is ELECTRICS,unless fully sealed,so start at the beginning and clean/replace any suspect parts(once done you know they will be free of problems)then check fuel tank/filter/carb for water contamination/dirt,then check all hoses for air/water leaks.you have only got the engine itself last....
Aug 12, 2010 | 1986 Subaru DL
1985 toyota r22 pickup(manual trans.) when i get on freeway and get up to about 45mph, in 3rd gear, the engine starts to bog down and i can not go any faster. it sat for 4 years with gas in tank. I have...
The problem may be the gas that sat in the carburator. Gas goes bad faster in smaller quantities. Have a look inside to see if you have "gummed" up passages, or jets. Don't forget to change the fuel filter.
Good luck. (I have an 89, and it's a great truck, 300k miles on it.)
Sep 26, 2009 | 1985 Toyota Pickup
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
RAN OUT OF GAS AND I CAN'T GET IT TO START AGAIN for a 2006 Lexus 250 is keyless start
have you primed the gas convertor?
there is a button on the side of it
Mar 14, 2009 | 2006 Lexus Is 300
Engine will turn over but will not continue to run
the fuel filter is in the tank on top of petcock that bike has a vacum operated petcock(fuelvalve)if the vacum hose is bad no fuel flow check the back of the fuel valve for a small hose that goes to the manifold make sure it is good put vacum on the hose wile hooked to the fuel valve and make sure that gas runs out of the hose give me a rate please hope this helps
Dec 13, 2008 | 1997 Honda VF 750 C Magna
Briggs & Stratton Gas Pressure Washer 20244 Logo
362 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
