The white westinghouse heavy duty washer and dry were installed as separate units. I have removed the top of the washer and placed the galvanized metal sheet into place. Does the dryer just sit freely on the washer top or is there some way of actually attaching it to the underlying unit. The manual was not provided. Please help. In need of stacking, Seattle
  • ambrown51 Nov 15, 2010
    I cannot believe they came up with such a lame system. How do you take the front off the dryer? Is the attachment solution visibly obvious once the dryer front is removed?
    As to back mounted/installed L-brackets: Do you just drill through the back of both machines or are there actual places for the bnrackets to attach?
    Please remember that this is an older pair (1994/1995), heavy duty models.
    Initially you stated that most people use the legs of the dryer for attachment. I assume they slip into slots on the open top of the washer. I mistakenly attached a galvanized cover, provided with the machine, between the two units. I was told by the delivery people years ago that I would need that part. It doesn't seem to do anything but get in the way.
    Please respond as soon as you can. This little dilemma is holding up the rest of the laundry room makeover and making me very nervous. Thank you.
    President:
  • 1,891 Answers
Most west stack units use the front feet to mount them . but in all cased some use a el bracket in the back side to keep it from moving . because it will fall off if not screwed to each other . if you remove the front of dryer it's east to mount the dryer to the top of washer . ,, or just use a el braket / 2 on the back side.. mm hopt this hepls feed back pls .
Posted on Nov 14, 2010
  • dennis dodge Nov 15, 2010
    the galvanized metal ? the only piece that i remember is the one that goes on the top of dryer . / there are different models of westhouse stack ( the g e style / bendix style / kenmore style/ ect / with your model # you can order the mounting kit for you machine from sears parts .com and you might be able to see the parts on there web . but most use genreal parts avilab from - like home depot or lowes hardware .. some model will not use the legs and only screws . . the only reason to take front off is so you can mount it with out seening the screws from the out side . . some installations have used a shelf above the washer and the dryer sits on it . / from a service point of view this is great . as if the washer needs service you only have to move the one unit . also if the washer or dryer needs replace ment you can do one instead of both units .. hope this helps mm
I have a 10 year old White Westinghouse washer. I don,t know the model #. It is heavy duty. Is it direct drive , or is it belt driven
Its belt driven only washer made by the Whirlpool corp. were direct drive during that time period 10 years ago
Sep 14, 2011 | Westinghouse Washing Machines
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
White Westinghouse model #MWX413REW The
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Dec 21, 2017 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse heavy duty washer
Check this website out. It has a good questions and answers section. I would guess that it is the water inlet valve in the washer, but it could be a few different things.
http://www.repairclinic.com/0088_11_1.asp
I know of a different site that has good prices on parts. I have ordered from them numerous times. Let me know if you need that link.
Oct 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
