OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
  • mcaolsen Nov 14, 2010
    Thanks for the responses. I am unable to get the option to boot from the CD
  • 922 Answers
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Posted on Nov 13, 2010
  • 162 Answers
1.If you have your OS CD or DVD (win XP, Vista or Win7),
2. Reboot your computer
3.Boot from CD or DVD
4.Let it run
5.Choose Recovery Console
6.When you are in Recovery Console type 1
7. Type Admin Password
8. type: chkdsk -r (to repair your system files)
Thanks
DiegoTech
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Tip
How to display Errors found and Repairs made by CHKDSK
<b> <p>How to display Errors found and Repairs made by the CHKDSK Command<br /></b> The Chkdsk command is used to verify the integrity of a file system and is capable of correcting discrepancies in system data files. This command has been with us since DOS days and has been modified by Microsoft as required to meet the requirements of new operating and file systems as they evolved. <br /> If you execute the Chkdsk command from a command prompt without using the F (fix) switch, Chkdsk runs in the read-only mode. As Chkdsk runs its tests on the drive, it displays the results of these tests on the monitor screen and the test results remain there for you to read until you close the CMD box.<br /> However there are several drawbacks to running Chkdsk in the read-only mode, especially on an active NTFS volume (usually C:) <br /> 1. Chkdsk cannot make any corrections to the drive while in the read-only mode.<br /> 2. If Chkdsk encounters more than minor errors, it will not complete all of its tests.<br /> 3. If you are running Chkdsk in the read-only mode on the active partition, Chkdsk frequently reports disk corruption and other file system errors which do not exist. This happens when the system modifies the disk during the Chkdsk testing sequence.<br /> Considering the above, there is little to be gained by running Chkdsk in the read-only mode.<br /> You need to run Chkdsk/F at the command prompt to test the drive and to correct any errors found.. As soon as you make this entry the system responds with:<br /> "The type of file system is NTFS. Cannot lock current drive."<br /> "Chkdsk cannot run because the volume is in use by another process. Would you like this volume to be checked the next time the system restarts? (Y/N)."<br /> After you key in "Y" (followed by enter) and re-boot, the operating system starts to load and you are advised that a disk check has been scheduled and unless you cancel it, Chkdsk/F will start to run in a few seconds. (Actually the file being executed at this time is Autochk.exe). Chkdsk will run through its phases but it only displays the test results on the monitor screen for about 2 seconds before the screen clears and the operating system continues to load!<br /> If problems were found wiith the file system, you will not have time to read any messages regarding what they were or what actions were taken. If corrupted files and/or orphaned files/directories were detected you would most probably like to know about it and other problems found by Chkdsk. So how do you display the errors found and actions taken?<br /> The answer is that since running Chkdsk/F is a system event, the information is recorded in the System Event Log under application events. To read the log, Click on Start, Control Panel, Administrative Tools, Event Viewer and Application. Look for "Winlogon" in the Source column and double click on it. An Event Properties dialog box will open and display the log for you to read..<br /> Yavacotech.<br />
on Dec 09, 2010 | Computers & Internet
Tip
How to display Errors found and Repairs made CHKDSK
Yavacotech.
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
May 01, 2013 | Dell Latitude E6500 Laptop
Windows has shut down to prevent damage to computer, Blue screen comes up every time and cant access not even in safe mode. -Error Codes: 650f : 0244 & 650f : 1A44 -Message: 185076...
Hello
This is a hard drive failure.Try holding down the f8 key while booting up and choose command promt.
Once there use Chkdsk .
Here is a link that explains how.This will check the drive and possibly repair it.If not you will need a new hard drive
http://support.microsoft.com/kb/315265
Aug 01, 2011 | Computers & Internet
I have a toshiba laptop with the windows vista,
Looks like some of the boot-up files or drivers are lost or corrupted. Your best bet is to re-install the OS. If you do it this way, you may not lose any files:
1) Boot from the OS CD-ROM
2) Choose "install OS" from the CDROM menu
3) Choose the "repair installation" option.
4) follow the instruction on the screen.
5) As soon as the computer boots successfully, open a DOS box screen and type "chkdsk c: /r"; answer "yes" to whatever question you are asked. Then close the DOS box screen and restart
Mar 20, 2010 | Twinhead N14RATK Notebook
Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
May 31, 2009 | Dell Inspiron 6000 Notebook
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Error code 0F00:0244 please help
basically, this error means "uncorrectable data error or media is write protected " or hdd has to be replaced. dell can do that automatically if your under warranty.
the error means hdd has bad sectors already. chkdsk /r cannot fix that. but theres a chance of reinstalling os on the hdd. os reinstall process freezing up is a possibility though.
Dec 19, 2008 | Dell Dimension 9200 PC Desktop
Won't start
Boot using Recovery CD and run chkdsk /R C: to fix errors then reboot.
You may have to install a 2nd copy of XP which will trash the first copy but at least leave your data files intact.
Aug 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
