Question about Freezers
Need manual for Belling BCF 28 10 c/ft. A+freezer which I have just purchased
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I have a belling chest freezer BCF 20 ... It has an orange fast freeze switch is this switch left on all the time????
No. That is like running it on "high power" full time and could cause it to wear out and stop working much sooner than it's natural life expectancy. It also uses up more than twice the electricity on your electric bill, than it needs to work normally. That setting could also be used in something like a store, where people open it up every few minutes, to keep it cold when it's opened so often.
That switch should only be used for emergencies, like after a power outage, or to quickly freeze foods that were fully thawed and need to be frozen quickly.
Oct 14, 2013 | Belling Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Temperature control are the lower numbers colderr or warmer?
Hi there, the higher the number the colder the fridge, unless the numbers are in degrees. If it's numbered 1-6, 6 is the coldest. -Alex
Aug 17, 2011 | Belling 3 cu. ft. / 85 liter Upright...
How do I get to the thermostat on a belling be809?
u can get parts online just put be809 thermostat and your area were u r too. it should bring a list of shops ect to buy it from ...try ebay too. or if you are in uk i can order it and send to u. bsc appliances 07779933829
Feb 27, 2011 | Belling 3 cu. ft. / 85 liter Upright...
Belling freezer wont freeze, red light remains on all time. Turned on and off, adjusted temperature setting, cleaned but nothing makes any difference. Can hear pump working but does not cool.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Belling 3 cu. ft. / 85 liter Upright...
Will not freeze. all lights are on at the frount and the red alarm is going off
red alarm is for temp. to high.
i am going to tell you the possible whys, not how-to fixes because that will take too long.
Compressor not running
short of freon
if have (freezer fan not running)
if have (condenser fan not running)
thermostat not working
defrost (if have) not working
timer (if have) not working
wasnt sure so i wrote if have... could not find a diagram of all the parts listed for this freezer
hope it helps alittle
Mar 27, 2010 | Belling 3 cu. ft. / 85 liter Upright...
Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
Nov 16, 2007 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
