Question about Visonik Dual Bass Box with Amplifier Car Audio Amplifier
Ok this problem is killing me...
I have a dual 10 in. visonik sub setup. They are already in a box and it also came with an amp. I'm unsure about the wattage of this system. About 3 yrs after having this system one of the speakers stopped playing sound. I figured it was the amp so I bought a new one. I got a 600w visonik, 4 channel. I hooked up the subs to this amp. I wired the left speaker to channel 2 and the right speaker to channel 1. But, the left speaker still does not work. I checked the speaker leads and everything seems to be connected just fine...i checked the wiring to the head unit...everything seems fine...idk wat the hell could be wrong...do u? thanks.
    President:
  • 624 Answers
Maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Posted on Jun 19, 2008
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
Popping noise from the subs
check rca wires you should spend good money on these it will help with road noise
Mar 25, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Does it sound hot cool and bad ***
Hello dylanholick,
Visonik is somewhat low-end car audio and band pass enclosures in general usually produce rather muddy and boomy bass. It will probably sound "bad", but not hot, and not cool.
If you aim is a good self-contained system with amp, sub and enclosure all in one, why not consider an Infinity Basslink, MTX Thunderlink, or perhaps a Bazooka. They're all available at www.crutchfield.com for little more than you'll pay for the Visonik and any of them will definitely sound better.
Hope this helps.
Jul 14, 2009 | Visonik 10" 500-Watt Single Bandpass...
Installation Guide for Car Subwoofers
MOST OF THE TIME AMPLIFIED BOXES ARE EASYER THAN REG AMPS, ALL U HAVE TO DO IS RUN UR RCAS FROM THE BACK OF UR HEAD UNIT TO THE AMP, THAN UR POWER LEAD, FROM UR BATTERY TO THE AMP, THEN UR GROUND MOSTLY ON THE FRAM OF THE CAR OR ON THE BRACKETS ON UR SEATS, THATS MAINLY ALL U NEED TO NO.
Jun 18, 2009 | Pyramid - PS46KX 35 Amp Power Supply Car...
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Visonik Dual Bass Box with Amplifier Car Audio Amplifier Logo
106 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
