Question about Dell Inspiron Desktop with Intel Pentium Processor
I have a Dell Inspiron 537s desktop. A CD fell from its bay into the CD drive of the computer and is still in there. The CD bay stays out and the door of the drive doesn't close. I opened the hard drive but am not able to remove the CD drive from it.
  • 2,567 Answers
Please refer to the following section from Dell Inspiron 537S service manual:
http://support.dell.com/support/edocs/systems/insp535st/en/sm/drives.htm#wp1187061
Posted on Nov 14, 2010
Hot to reset bios to defaults dell 537s
You can remove the CMOS battery for 30 seconds and then insert it.
May 02, 2014 | Dell Inspiron 537s PC Desktop
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
How to eject cd from dell inspiron
Press the button the cd drive door or click Start/My Computer then Right Click on the CD Drive and select EJECT.
If it is stuck you will need to take a Paper Clip (Gem Clip) and straighten it out. Then look for the tiny hole on the CD Drive door and push the Paper Clip (Gem Clip) into the hole and Press the the button on the drive door. As you Press the button on the drive door, push the paper clip in and the door will pop open.
Don't worry about breaking something, that is why the tiny hole is there.
May 04, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
CD BROKE IN DRIVE - NOW DOOR WILL NOT OPEN
Seems like some of the particles from the broken CD have remained inside. For manually opening up the drive there is a small hole in which you can insert a straightened paper clip. The drive bay will budge a little and you can pull it out manually. Secondly maybe the belt driving the open/close system has gone weak. Try tapping ******* top of the drive right after pushing the eject button. After you have got it opened i suggest you remove the drive from the PC and do a detailed cleanup by completely dismantling the drive.
Jan 04, 2012 | Dell Inspiron 570 MT PC Desktop
Where is the sd card slot on a dell inspiron 546?
please make sure your computer has the SD card located in the media bay area under the CD/DVD drive. if it is not there then you do not have a SD card slot/reader.
Nov 25, 2011 | Dell Inspiron 546 MT Desktop Computer
My CD drive panel stays open/down after a cd has been insertedhe cd works - how do I repair the door unit ?
the exterior door is spring loaded, so the door is either in a bind or the spring is damaged or missing.
If you can't fix the spring/door, you can get a replacement here:
http://shop.ebay.com/i.html?_kw=530&_kw=Inspiron&_kw=front
Jul 16, 2011 | Dell Inspiron 530 Desktop Computer
My Dell Inspiron 537s stopped working and won't turn on. There is a green light in the back when I plug it in, but the power button in the front does nothing. I am assuming it is the power supply, but...
The only way to determine if the power supply is no good without replacing it is to get a Volt Meter and test the Output on the current Power Supply. If you are getting the correct Output Voltage (correct Output Voltage may vary from computer to computer) then it is not the power supply, but if you are getting a 0V then your power supply might be damaged or blown a fuse, or just simply dead.
You can try to see if you can buy a power supply with a return policy just to see if that fixes the issue.
Please rate if this helps
Mar 15, 2011 | Dell Inspiron 537s (DDCWRA2_6) PC Desktop
Wull not play commercial DVD on DVD player installed
Some viruses disable removable drives, so be sure that your antivirus is current an you have done a complete scan.
If it recognizes that it is a DVD, the software might have to be reinstalled. You can try opening the DVD player manually, it may recognize it then. There are several firmware updates on the dell site for the DVD drives.
Try booting the computer with a restore disk (just abort if it actually starts). If the drive does not recognise dvds (on boot and if you open the computer icon and see if the disk shows up) as a last resort before replacement, you might try a commercial drive cleaner.
Aug 09, 2010 | Dell Inspiron 537s PC Desktop
Dell Inspiron Desktop with Intel Pentium Processor  Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
