Question about Whirlpool Washing Machines
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
    President:
  • 1,554 Answers
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Posted on Nov 14, 2010
My 99 dodge 3500 diesel wont start it turns over but wont start where do i start
If you ran it out of fuel, You may have to prime your sytem first. There could be a hand pump located near your fuel pump. There are also several prescreen filters throughout the fuel sytem. They are located at some of the banjo fittings. They have to be clean to allow fuel through. If you have access to the fuel filter, make sure that is full of fuel and clean. You may have a bleed valve for removing air from the system. Or removing a fuel line located at the highest point and cranking engine until fuel comes out, then reattaching it Just some ideas where to start.
Aug 30, 2014 | Dodge Ram 3500 Cars & Trucks
I've a whirlpool sixth sense washer and the clean pump light comes on mid cycle. I've cleaned the pump filter, cleaned the pump, checked the pipes for blockages, and today replaced the pump, only to fine...
You might have a loose connection to the pump or from the pump to the CCU Remove the top of the washer and make sure that the wire coming from the pump to the CCU is fully in and it's not loose
Apr 30, 2014 | Washing Machines
Engine runs but only a steam of water comes out of gun with trigger on. washer is stored in a heated garage in winter.
you need to remove and clean the unloader valve. The way this valve works is when you release the trigger the pressure is diverted around the pump through the inlet side so you don't cause damage to the pump. This valve is usually located next to the discharge pipe on the pump where your pressure hose hooks up to. Remove and clean. Be sure to clean port that you remove the valve from also. Use carburetor cleaner. Lubricate the valve with a light coat of lithium grease. This should cure the problem. If not let me know.
Jul 25, 2011 | Briggs Stratton 020273 Elite Series...
The light is on to clean pump , where is pump located ??
Pump is usually located below the washing drum. You may well have to take the back off the machine to access the pump
Feb 06, 2011 | Washing Machines
The fuel pump is failing, where is it located on a 2004 Jetta GL 1.8 sedan?
Hello
Fuel pump is located in the fuel tank.
you need to drain the fuel tank
and then remove and let the fuel tank down away from the floor of the car there will be 2 fuel lines to disconect too
once the tank is down in the center top of the tank there is where the fuel pump is at there is a ring that holds the fuel pump into the tank this comes off by rotating to the left
the old fuel pump comes out
clean off where the new fuel pump goes
in stall the new pump and ring
raise tank
install lines and strap
add gas
good to go
Jul 18, 2010 | 2004 Volkswagen Jetta
Ariston ventless dryer- "Clean Filter" light won't turn off, so dryer won't start
I had this same problem. The dryer would turn on for a few seconds and I could hear the water pump working followed by the "clean filter" light. This dryer has a float sensor which detects whether the pump is successfully getting rid of the condensed water. The only problem is that lint and other particulates condense out in the water and over time the float sensor gets stuck in the up position. The Ariston call center explained that the float sensor can trip the "Clean Filter" light.
In any case, the float sensor is located in the back of the dryer where the pump outlet tube comes out (when facing the back, it is in the lower right). I had to take apart quite a bit of the dryer to get access to the sensor. I ended up taking the near side off to release the plastic snaps that hold the cover over the sensor.
To fix the sensor, all I had to do was clean out the "bath" that the sensor floats in. And then figure out how to put it all back together.
Oct 06, 2009 | Ariston Technologies ASL75CXSNA 24"...
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
