Question about Whirlpool Inglis IP8200 Dryer
Dryer heats briefly, then cools down, takes hours to dry
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 04, 2011
Heat coils turn on and heat for a very short time then turn off briefly turn on again it takes 2 hours for a load to dry
Make sure your vent pipe is clear from the back of dryer all the way outside....A clogged or restricted vent is the most common cause of slow drying...
Nov 03, 2010 | Kenmore 62602 Electric Dryer
SENSEON DRYER WILL RUN GOOOD FOR 1 OR 2 CYCLES IF STILL WET AND PUT THEM BACK WILL NOT HEAT UP AND DRY THEM WILL GO FROM SENSING TO COOL DOWN THEN WONT DRY ANYTHING
HI,
t normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequentlythere's an obstruction in the vent duct from the dryer to the outsideof the house. For the dryer to heat properly, the duct must be cleanand clear of lint or any other substance.
Heating element Yourdryer's heating element may be partially burned out. If it is, yourdryer still heats, but at such a low temperature that it takes three orfour times as long to dry the clothes. If the element is partiallyburned out, replace it.
Internal ductwork Yourdryer has some internal ductwork. If it gets clogged, your dryer can'tdry properly. In most dryers, to get to the internal ductwork to clearthe clog, you have to substantially disassemble the dryer. A quick wayto check for internal clogs is to remove the lint filter and use aflashlight to inspect the inside of the duct. If it looks clogged andyou can't clear it using your vacuum, contact a qualified appliancerepair technician.
Cycling thermostat Althoughthis isn't a common problem, one of the thermostats that controls thetemperature in your dryer may break and cause the dryer to heat poorly.If so, you need to replace it. The thermostat is usually a small,round, black device mounted to an oblong steel plate. The plate ismounted to the internal ductwork with two screws.
Jul 29, 2008 | Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
There is no heat when drying, drier works, no heat, only coolness.Clothes take hours to dry.
Either the element burnt out or the limit switches have failed. the switches can be bipassed, but replace asap.
Aug 30, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Heating element stays on
stat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Mar 07, 2009 | Whirlpool LER7646J Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Oct 07, 2007 | LG DLE2514 Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
