Question about EPoX EP-8RDA6+PRO Motherboard
I got an epox ep8rda6+pro board the the led debugger says ff but i need the debug codes & what they mean & i have no video during post
5 Suggested Answers
dlundmark
  • 797 Answers
SOURCE: Epox EP 8RDA3I
Hello tenkist:
Many error codes in mother boards are similar.
Saying that, you need to get to the maker of the board, and find the information from them.
Sending them an email under support, will most likely solve what you need.
Posted on Sep 02, 2008
Vaio Tech
  • 166 Answers
SOURCE: I have an ep-8kta3+pro m/board. Occasionally it
FF mean kind for computer geeks Fatal Failure meaning the only solution is geting a new one thanks and good luck
Posted on Oct 21, 2009
elstretchie
  • 140 Answers
SOURCE: Epox 8K9A2 motherboard ? hangs @ POST CODE "26"
Gday mate , you will have to start with BIOS settings on boot when it detects the drives at the bottom of the screen will be a press ( this button) to enter setup probably delete or F8 go to there and probably set standard defaults would be the best option in the list do tha and follow the prompts back to startup screen, unless it comes up with NTLDR missing which is in the OS files
Posted on Apr 07, 2010
  • 18 Answers
SOURCE: Hi, got an AMD computer with an Epox EP-8KTA3 pro
I have an EP-8KTA3PRO, Code FF on the LED means "System Booting" the BIOS has passed all Post checks and control has been passed to the Operating system. It stays at FF as long as machine is on and operating system is running. I would suggest the problem is with the operating system, or possibly hard drive corruption? Do you get any error messages on the screen after the Bios checks? you say it does boot? Never Flash the Bios unless absolutely necessary.
Just in case you get it working you may be interested to know that the manual insists 1GB is maximum memory but that is a lie, I have just installed 1.5GB (3 x 512MB) which is the true maximum. But it ONLY recognises the full 1.5GB if you populate DIMM 0,1, and 3 - leave DIMM 2 empty.
Good Luck
SB
Posted on Sep 02, 2010
Hi, got an AMD computer with an Epox EP-8KTA3 PRO motherboard with Apollo bios.It will boot,but wont load O/S and the fault code LED's show FF. I am trying to find a manual to interpret the fault code and...
Good Luck
SB
Jul 15, 2010 | Computers & Internet
Microsofrt windows xp pro [debugger enabled]windows loads and stalls or freezes on entry cant go any further or open anything
:) For what purpose you need a debugger when you can not fix your own mess :) ?!?
Which debugger have you installed? It must be a ring 0 i guess if auto loading drivers (SoftIce, Syser or RR0D .. WinDBG will not crash your OS )
Just go SafeMode and remove all autorun entries for the debugger ( drivers included ), use autoruns from M$ Technet ( SysInternals ), or just System Restore to previous point where you were not trying things that are out of your league ;)
A piece of advice :
For debugging use dedicated machine or virtual one
Nov 20, 2009 | ASUS K8V-MX Motherboard
I have an ep-8kta3+pro m/board. Occasionally it fails to start up and the LEDs are stuck on FF. What does the code FF mean?
Oct 20, 2009 | EPoX EP-8KTA3+ Pro Motherboard
JetWay J939GT4-SLI-G always showing "FF"
Try disconnecting all power connectors to the hard drives and CD-Rom drivesin the system. Leave only the motherboard connectors and the video card connector if there is one. Re-seat your RAM and then try. If it boots up, the power supply is being overloaded and it will not power on the PC.
Sep 27, 2009 | Computers & Internet
Computer does not reboot after a reboot command
usually it's a faulty RAM, doesn't it show an error on/during POST ?!?!
maybe just a loose connection between board and keyboard?!
if you can, debug the process:
1 - check cables
2 - disconnect all cables except keyboard, mouse and monitor
-- REBOOT
3 - open the case
4 - how many RAM dimms?!?!
5 - if more than 1, remove one of them and REBOOT
exchange them and reboot again.
this should help to identify the problem.
if all fails.... maybe a faulty board, or processor.
or some pci card.
Sep 16, 2009 | EPoX EP-3VSA Motherboard
DASC Common Language Runtime Debugging Service
you most likely need Jave Runtime Installer installed
java download link
After installation try and run it again - if that does not work post back and let me know and I will try and assist further
May 07, 2009 | Video Game Consoles & Games
Epox EP 8RDA3I
Hello tenkist:
Sep 02, 2008 | EPoX EP-8RDA3I Motherboard
Won't run POST
mobo battery is batery in video card try pci differt video 1 pice ram or the other power grounded well with all screws
Jan 17, 2008 | Soltek SL-915G Pro-FGR Motherboard
Soltek SL-865PRO2-FGR Motherboard Problem:
Generally an FF code means either a dead board or a dead motherboard... =/
Although you may not have changed anything, motherboards can die for the strangest of reasons, and in my personal experience, this is what this means.
Nov 07, 2007 | Soltek SL-865PRO2-FGR Motherboard
EPoX EP-8RDA6+PRO Motherboard Logo
113 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Greg Cann
Greg Cann
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
