SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: Precor 9.4 Treadmill Incline Problem
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment
was not working.
So, I did the following.
1. Turn off, unplug the
treadmill and wait for an hour (this is for safety
2. Remove the
black motor cover
3. Observe the transformer to the right of the
motor and towards the belt ( I point to it in the video)
This
transformer converts DC electricity to AC electricity and the AC current
goes directly to the Incline motor which is in the black box towards
the front of the machine.
4. On mine the wires had come loose from
the transformer, they were soldered on very poorly, the wires are stiff
and you should be able to see 4 wires coming from the top of the circuit
board and plugging into the transformer, I had three of the 4 wires
loose.
5. If you are not comfortable working with electronics or
soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you
just go poking around in there with metal objects, get a friend who
knows how to solder or hire someone.
6. It took about 5 minutes I
just heated up my $10 soldering gun from radio shack and soldered all
the loose wires that were about a millimeter away from the tabs on the
back of the transformer, and VOILA! The incline now works!
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
