Question about McCulloch Garden
Oil tank runs out before the fuel tank McCulloch 2214AV Chainsaw empties before fuel tank' Adjustment required to Automatic Oiling System
I think you have missed the mark with this answer. The fuel is not automatically mixed, it is always pre-mixed. The bar auto lube pumps out way too much bar oil. Mine does the same but I don't know how to adjust it.
Posted on Jul 05, 2015
  • 454 Answers
I would just pre mix 50:1 in fuel can and skip the auto mix.
Posted on Nov 13, 2010
I need to find a oil tank for mcculloch pro mac 3505 av16
Do you mean a replacement oil tank for your chainsaw? The following link shows a parts breakdown for your chainsaw. http://s30387.gridserver.com/partsDiagrams/McCulloch%20Late%20models.pdf
Verify that part #14 is your tank (MC-300260). I will tell you this...it is a hard part to find. You may be able to get one here.
https://store.chainsawr.com/collections/mcculloch/products/mcculloch-mac-32cc-to-38cc-chainsaw-oil-tank
Nov 09, 2017 | McCulloch Garden
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
I have a pm 605 McCulloch chainsaw and no matter what I do I cannot get the oil pump to work. Any suggestions on what I can do
Before you toss your saw you can find parts ! I would first chick the filter in your oil tank if equipped, then clean and check your pump, they are simple and can be replaced, however most are behind the clutch. Most have adjustment to allow for more or less oiling. If you tried a thinner oil and flushed it out, and it still doesn't work then you may need the pump.
Jan 10, 2015 | McCulloch Garden
WHAT KIND OF OIL DOES THIS USE?
Chain oil ( non fling ) in the oil tank, and a 50-1 fuel oil mix in the fuel tank, only use good quaility two stroke oil designed to run at 50-1, preferably oil produced by a reputable chainsaw manufacturer.
Feb 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to adjust idle on McCulloch Mac 2214av chainsaw
Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. . Start with 1 1/2 turn out from all the way in. Be sure the filter is clean, You can use starting fluid or old school lighter fluid to aid starting if has been sitting for some time.
Oct 10, 2010 | Garden
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Jun 18, 2009 | Standard Oregon Chainsaw Chain For...
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
call 1-800-521-8559 select parts, ask them to email a owners manual to you, it's free, it's EZ
Oct 17, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
322 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
